What causes that beautiful sound? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-24-2012, 08:35 AM Thread Starter
Shortly after buying my 2004, I slapped on a 4" turbo back. Its pretty tame sounding-until about 2000-2200 rpm when it just erupts under any sort of throttle, especially with a load, then quiets back down. Don't get me wrong, it's a lot of fun next to rock cuts and overpasses. But what causes that sudden explosion of engine sound?
2004 F350 XL 4x4, 6 spd, Edge Juice w/ Attitude, EGR Delete, 4" MBRP turbo back, FASS 95, South Bend Ceramic/Kevlar Clutch
cornbeltbandit is offline
post #2 of 7 Old 06-24-2012, 08:37 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
That's the sound of power my friend!
It's when your turbo spools up and dumps about 20 psi into the engine.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 7 Old 06-24-2012, 08:39 AM
DoubleDpsd's Avatar
It' a v8.....so, the V shape the pistons move in?
dunno, just guessing lol
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #4 of 7 Old 06-24-2012, 09:44 AM
Correct me if.I'm.wrong but I believe it when the turbo.vains are completely open is when you get that v8 rumble
mx730md is offline
post #5 of 7 Old 06-24-2012, 09:47 AM
atvrider93's Avatar
Quoted: 8 Post(s)
Big v8, 7.3s do the same........just without all that whistle
Sent from my DROID BIONIC against my will
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #6 of 7 Old 06-24-2012, 07:01 PM
jerg_064's Avatar
I say torque peak. My old 302 F150 did the same thing right around it's TQ peak when it had longtubes and true duals.
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
post #7 of 7 Old 06-24-2012, 07:16 PM
jimmyv13's Avatar
Quoted: 47 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
If you like that, try the SRL tune.
2015 F250 CCLB Lariat Ultimate
jimmyv13 is offline
