Do 2006 and 2007 absolutely need Bulletproofing?
Do the 2006 and 2007 absolutely need Bulletproofing?
I thought I read on here somewhere Ford fixed most of the issues by then. I'm lookin for my first F250 and not sure if I should go 6.0 or 7.3 |
My 06 needs an oil cooler as we speak...why not do the studs and gaskets and egr delete as a preventive measure?
If you use the truck to its potential, it will break...simple as that But I must ad, I bought an 06 for the reasons you said...the issues were said to have been resolved by these years... |
I test drove a 2006 yesterday. Do you know what this thing is?
Yea someone put in a coolant filter. A must have for the 6.0 to get the trash out of the coolant to prevent or prolong oil cooler life.
Also ARP head studs are a popular option as well as the OEM headbolts are weak. Stock trucks should be fine but if you max out your rig or add power they usually will fail at some point.
I would check for studs on that one...chances are they might have done that as well...
Are the gaskets prone to blowing on the 06-07 provided the egr ans oil coolers are dealt with? |
Sorry to be such a noob, but how do I check the studs?
Look where the heads are just under the Alternator on the block. If you see bolts then you got head bolts, if you see a Nut screwed on stud then you got head studs. There should be a pic on here somewhere of just google it.
Depends on the gaskets, OEM gaskets are the best. Black Onyx gaskets will fail. Once the EGR cooler is gone and Extended Life Coolant (ELC) is put in, your failure points are gone. Now the oil cooler would need to be replaced after the chemical flush, because it will get clogged with all the crap in the cooling system. And putting a coolant filter will get all the other things floating around in the cooling system, like casting sand.
Look at the front of the passenger side head...you would be able to see a stud with a nut clamping the head to the block. Otherwise you will see a hex head bolt. Studs are good. Oem bolts, not so much
