FICM, Injector, or worse - Ford Powerstroke Diesel Forum
Old 06-21-2012, 06:09 PM
Ok I own an 07 6.0 that started running ****ty yesterday. So today I did a voltage test on the FICM and I get 48 on the key and 48 running. I cleaned the EGR and changed the oil.
The truck doesnt run AS ROUGH but; it still blows black smoke and IS NOT running smooth.
I also ran a check on it and there are NO CODES.
So what are your thoughts on this?
Thank you
Old 06-21-2012, 06:18 PM
Check FICM voltage while cranking. What oil are you running? Run revx if you haven't before. See if that clears it up.
Old 06-21-2012, 06:37 PM
Check the connectors on the back of the ficm.
Old 06-25-2012, 06:22 PM
#8 injector was bad
Old 06-25-2012, 06:23 PM
Well at least you got it
Old 06-26-2012, 06:54 PM
Good evening! I'm new on here and mainly just doing some reading to get up to speed now that I own a 6.0. I'm just curious how, without any CEL, you were able to track down the problem to an injector. What lead you there as opposed to anywhere else?
