Oil pan removal on 6.0L - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-21-2012, 09:08 AM Thread Starter
Truck is an 04, 4x4. Can you replace the pan without pulling the engine? I'm 100 miles from the truck so can't look at it.
Thanks
Kappa Sig is offline
post #2 of 9 Old 06-21-2012, 09:54 AM
Glow Plugs Only
dee004's Avatar
I remember seeing a thread where a guy changed a rusty oil pan by raising the engine a couple of inches. I sure a tech will chime in.
05 F250 CCSB 4X4, 05 VW TDI
4"Banks Turbo Back, ARP Studs & OEM Gaskets,
Coolant Filter, Blue spring, Zoodad
Bypass Oil Filter, Kitty By By, Standpipes dummy plugs
BPD oil cooler, EGR Delete, CCV Mod, BPD Oil Cooler, SCT SF3
dee004 is offline
post #3 of 9 Old 06-21-2012, 09:54 AM
No I am pretty sure no, have to pull engine. Oil pan bad or just gasket.
letitsno is offline
post #4 of 9 Old 06-21-2012, 10:05 AM
Glow Plugs Only
dee004's Avatar
Click on link below. See the last post by M-Chan Ford Tech
DARE I ASK......Oil Pan Replacement.
dee004 is offline
post #5 of 9 Old 06-21-2012, 10:34 AM Thread Starter
Truck is a wrecked total loss that I'm rebuilding. When it was wenched out of the ditch the oil pan was "dented". If it was easy to replace I was going to do it. If Engine has to come out, I'm gonna try it like it is. No leaks apparant. It isn't that bad. But a little concerned with where the pick-up tube is. Center of pan or kicked off to the driver/passenger side? Damage is more on the drivers side, rear of the pan.
Thanks all!
post #6 of 9 Old 06-21-2012, 11:39 AM
May be a stupid question but I wonder you couldnt just cut the cross member out and weld a new one in after the job is done? With proper bracing etc the frame wont twist. Just curious is all, A good fabricator can make it look better than new
2004 F-350
Edge Insight CTS
4"MBRP Cat Delete
SCT tuned by Innovative
ARP Head Studs
03 Turbo
Leveled on 35's
Sinister EGR Delete
6.4 Banjo's Blue Fuel Spring
ELC Coolant/Sinister Filter
yarmish is offline
post #7 of 9 Old 06-21-2012, 11:40 AM
Quoted: 356 Post(s)
Feedback Score: 5 reviews
I have taken the oil pan off by lifting the engine up a bit... Then I pulled the engine out through the front of the truck
Done it twice in the last year
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #8 of 9 Old 06-21-2012, 02:33 PM
BlakeS's Avatar
How hard of a job is this? What king of hoist / engine stand are you using to hold such a monster motor?
Blake
2004 F350 CCSB
Flat bed for sale.
BlakeS is offline
post #9 of 9 Old 06-21-2012, 02:38 PM
Quoted: 356 Post(s)
Not "too" hard...
I could take out the engine and tranny out in a weekend with a helper.
This should be a day or two of work for a bigginer i assume.
Just a regular 2 ton Harbor Freight engine puller
Studded and Deleted
