2003 6.0 Scanguage EOT problem - Ford Powerstroke Diesel Forum
Old 06-21-2012, 06:01 AM
I have been scratching my head on this one. I have read as many posts as I could with no answer. My EOT just reads -numbers. I have tried three different codes with no change. Has anyone run into this on their 2003?
I would love to figure this out otherwise this scanguage is almost worthless to me.
Sent from my Xoom using AutoGuide.com App
Old 06-21-2012, 07:47 AM
It took me 3 tries to get all the codes punched in right for the EOT.
Old 06-21-2012, 07:59 AM
I've tried many times. Is there another setting I need to change?
Old 06-21-2012, 08:02 AM
I double checked the code. Looks correct.
Which code did you use?
Old 06-21-2012, 08:27 AM
I got the codes from a thread in here. I went into the menu on the scangauge and went to the x gauges menu and then to the EOt set up and then entered the 3 codes and then back to the gauge menu and then scrolled through until the EOt came up. There is a video on youtube of someone setting up their scangauge on their 6.0 that I watched that made things clearer.
Old 06-21-2012, 08:58 AM
Here is the video, or at least one.
