Studding a 6.0 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-20-2012, 02:19 PM Thread Starter
JayAF98's Avatar
Studding a 6.0
I'm wondering when you guys think should be the time to get my engine studded. What point is it required? 500 hp mark? Higher? 100000 miles? I know some will say asap but I'm looking more for when it's required. With my current setup I'm not near 500 hp and plan on doing it eventually.
Sent from my DROID X2 using AutoGuide.Com Free App
JayAF98 is offline
post #2 of 7 Old 06-20-2012, 02:26 PM
Quoted: 356 Post(s)
Feedback Score: 5 reviews
Straight pipe and an SCT with a custom tune written for non studded trucks put you at about 400hp.
That is the max power you can run without studding... Once you stud it you can put a stronger tune in and start modding injectors, turbo Ect.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #3 of 7 Old 06-20-2012, 03:05 PM
Razorsedge's Avatar
When the head gaskets blow.
2005 F250 4x4 King Ranch 6.0
Two tone removed, Quad Captains, High idle mod
Edge Insight CS w/ EGT, fuel PSI, and turbo timer
4" turbo back straight pipe, Dieselsite coolant filter
BPD FICM, '03 turbo, IPR gen2 delete, Zerex ELC
Goodyear Duratracs, Tuned by Matt@Gearhead
Razorsedge is offline
post #4 of 7 Old 06-20-2012, 03:32 PM
The Silent Service
colo_dually's Avatar
Quoted: 12 Post(s)
Personally, I like the dependability that comes with a studded 6.0L. Prior to my HG's and studs, I only ran stock programming.
When should I stud my truck?
That is a question that in reality the owner is the only one who has that answer. A basic tune and exhaust will put around 400HP to the rear wheels, and there are plenty of guys around without studs on that setup. I recommend looking over my Bullet-Proofing thread and come up with a game plan that will work with your build goals and budget. (I wouldn't push performance more than the tune on stock bolts).
Write Up: Bullet-Proofing the 6.0L PSD.
There are a few ways to handle studs
1) A one for one replacement - Only works if you know your heads and gaskets are good, and done at the same time as an oil cooler rebuild and EGR solution.
2) Cab on/off head removal, when the HGs fail - roll of the dice, ideally with a monitor and you not beating on the truck, you should be able to prevent the HG's from letting loose in the first place. However, waiting for the failure could compound the issue by it being at the worst time (like in the middle of a vacation).
3)Cab on/off head removal, before the HGs fail - good particularly because you set the time that the truck goes down, and take the time to ensure the job is done right. (This is my recommendation, and again rebuild/replace your oil cooler and install your EGR solution.)
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 7 Old 06-20-2012, 03:39 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Guess my truck didnt get that memo
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 7 Old 06-20-2012, 03:43 PM
Quoted: 356 Post(s)
And then..........there are exceptions like Dave
j/k
Studded and Deleted
post #7 of 7 Old 06-20-2012, 04:35 PM Thread Starter
JayAF98's Avatar
Colo dually, that's pretty much what I'm looking for. Like I said before I'm probably in the 400 range. The guy I bought the truck from already did the exhaust (cat back, the cheap bastard). I added a cold air and h&s mini maxx. It's my dd and I don't romp on it very often. My mini maxx is almost always set to mild. Head studs are in my future when money allows. Just trying to get some input on what everyone else thinks
JayAF98 is offline
