Another Sccangauge mount question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-19-2012, 08:10 PM Thread Starter
Quoted: 3 Post(s)
Hi All,
I realize the scangauge mount talk has been beat to death but I remember reading several months back a post on one of the forums about a guy that made a cheap scangauge mount that hooked to his headliner above the rearview mirror. It was a full DIY type solution and only cost a couple of bucks but looked pretty decent. I have searched high and low and can't find it for the life of me. I'm not even sure which forum it was on.
I realize I could get a blendmount but I plan on getting an edge insight before too long and don't really want to drop the extra $50 for it.
Just thought somebody may remember seeing it.
Thanks,
Steve
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
"The Little Blue Spring"
Full coolant flush - now running CAT ELC
New oil cooler, standpipes & dummy plugs, 6.4 Banjo bolts, STC fittings
EGR Delete
SCT Tuner running "Looney"
Edge Insight with EAS-EGT
Rotella T-6 5W40 and Rev-X
4x4ff is offline
post #2 of 11 Old 06-20-2012, 08:37 AM
DieselV8's Avatar
I just saw that thread not to long ago, just do a search or check the mod section it might be in there.
06 F250 Crew Cab, Lariat-FX4, ScanGauge II, High idle mod, Heated mirror switch mod, Sinister bypass oil filter and coolant filter, Fumoto valve, Zoodad, Blue Spring
DieselV8 is offline
post #3 of 11 Old 06-20-2012, 11:09 AM Thread Starter
Quoted: 3 Post(s)
I have been searching and can't find it. Thats why I was hoping someone else would remember where it is.
Steve
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
EGR Delete
4x4ff is offline
post #4 of 11 Old 06-20-2012, 11:29 AM
DieselV8's Avatar
Is this thread you were looking for. Where would i mount a scangauge 2? Pics would be great
DieselV8 is offline
post #5 of 11 Old 06-20-2012, 12:39 PM Thread Starter
Quoted: 3 Post(s)
No thats not it. The one I'm looking for was kinda a DIY thread. I am thinking he used some kind of screen clips to mount it from the headliner above the mirror. He had very detailed pictures if I remember correctly. Thanks for the try though.
Steve
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
EGR Delete
4x4ff is offline
post #6 of 11 Old 06-20-2012, 01:44 PM
DieselV8's Avatar
I haven't seen that one.
DieselV8 is offline
post #7 of 11 Old 06-20-2012, 06:29 PM Thread Starter
Quoted: 3 Post(s)
Hey all,
I finally found the site I was looking for. Its on a Tundra site but the principle is the same. Gonna try something similar within the next couple of weeks. For those interested here is the link Scan Gauge II Do-It-Yourself Mount/Bracket
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
EGR Delete
4x4ff is offline
post #8 of 11 Old 06-20-2012, 06:46 PM
squirtgun's Avatar
I am using a window shield cell phone mount for my SC2 I think I paid about $12.It has a flexible arm I have it facing me as I drive just below the grab handle.
2003 6.0L F250 4x4 Lariat
Fog Light Mod,High Idle Mod,Zoodad,Hose clamp taligate mod,08 rear bumper,Sinister EGR delete,ELC EC-1 coolant,Edge Juice,MKM(Sinister)coolant filter,HFCM drain plug upgrade,diy FICM repair(steady 48.5v now),DIY CCV mod,Torque Pro,Blue spring upgrade,Aluminum radiator,05 headlights,LED foglightd
Wish List/Things to do
Y-pipe,fuel pressure gauge,diy oil bypass(maybe centrifuge),oil pressure gauge
squirtgun is offline
post #9 of 11 Old 06-21-2012, 07:35 AM
Will the cable from the scangauge reach from the mirror area to the OBD port or do I have to buy something?
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #10 of 11 Old 06-21-2012, 07:41 AM
DieselV8's Avatar
I couldn't make my cable reach the mirror.
DieselV8 is offline
