Factory Oil Cooler - Ford Powerstroke Diesel Forum
post #1 of 29 Old 06-19-2012, 06:07 PM Thread Starter
Factory Oil Cooler
So I am brand new to the Ford 6.0 scene and diesels for that matter. Bought a 2003 F350 CC Dually 4x4. I have read for days on end about these engines and the problems associated with them. So after all my reading and "figuring" I finally have a question. Why would anyone ever put a factory oil cooler back in the truck once the first one was clogged and had to be removed? Here is what I think I read over teh last few days.
The coolant is bad or maybe it is not, either way the coolant clogs the oil cooler causeing the EGR cooler to overheat and fail which causes oil and coolant to mix and dump coolant into the cylinders. At this point the cylinders have too much pressure and the TTY head bolts stretch causeing head gasket failure. Of course this is the condensed version.
So, why not put an aftermarket oil cooler back in if the problem begins with the factory oil cooler and coolant combination? I understand that if thecoolant is changed more often the new cooler may never fail. I also understand that it is very difficult, if not impossible, to get all the old coolant and gel/sludge/sand out of the coolant system. Is it a cost issue or does teh majority believe something else is the cause of teh problem to begin with, like the EGR?
Thanks, cool forum.
seeemmiss is offline
post #2 of 29 Old 06-19-2012, 06:13 PM
nylyon's Avatar
For me it was simply cost, so far I am having far better success with ELC coolant, time will tell I suppose.
- Karl
2003 F-250 Crew Cab Short Bed Lariat PSD 6.0 Automatic FX4 Edge Insight with EGT Probe. Coolant Filter. All 6.0's need gauges
nylyon is offline
post #3 of 29 Old 06-19-2012, 06:14 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Because adding a basic aftermarket oil cooler isn't that easy. It isn't just add a cooler and be done with it, you need to maintain oil psi with a large enough air/liquid cooler and integrate a oil filter/housing/hoses large enough to handle any psi drop/spike.
There are aftermarket external oil coolers that are available. The best one is pricy but is well worth it (BPD). The others are cheaper and are questionable on the engineering.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 29 Old 06-19-2012, 06:17 PM Thread Starter
The first answer, I understand. The second is over my head. I knew there was reason though. Thanks for the replys. I ask after reading the Paramedic thread and another on coolant. I noticed that the paramedic put a BPD oil cooler on his truck and he had no experience with any type of mechanic work. Not syaing one is better than the other, just wondering.
Thanks again.
post #5 of 29 Old 06-19-2012, 06:21 PM
Powerstroke Techie
Lilpooh's Avatar
There is only one company that offers a "upgraded" OEM oil cooler design, but has been shown to make the oil temps run hotter because the coolant passages in the oil cooler flow too fast to keep oil temp down.
So now your only choices are an aftermarket external oil cooler like BPD, or a DIY external oil cooler kit, or keep using the OEM oil cooler.
Lilpooh is offline
post #6 of 29 Old 06-19-2012, 06:24 PM Thread Starter
I understand now. So you either pay $375 for factory and try to keep it clean or $2,000 and still keep it clean. I see why so many stay with factory. I probably will too.
post #7 of 29 Old 06-19-2012, 06:29 PM
Powerstroke Techie
Lilpooh's Avatar
With the BPD kit, keeping the coolant clean isn't as important because there is no coolant passages to clog. You eliminate coolant clogging issues.
Lilpooh is offline
post #8 of 29 Old 06-19-2012, 06:37 PM
Korx's Avatar
$250 from trousley for a factory cooler
Korx is offline
post #9 of 29 Old 06-19-2012, 06:49 PM Thread Starter
Thanks for the tip!! BPD had it for $375. That is where I got the price I think. So much to learn on the truck. My goal is to never have to change the cooler. The OASIS report shows head gaskets at 83,000 miles and a turbo at 95,000 so at 132,000 I am hoping I can keep it clean. The last owner kep all fluids changed every year and oil changes every 5,000 miles. Older man and was real good about maintenance.
Wish me luck!!!
post #10 of 29 Old 06-19-2012, 06:51 PM
Powerstroke Techie
Lilpooh's Avatar
Wish me luck!!!
You may never have to change out your cooler, this is why a monitor/gauge solution is so important.
Lilpooh is offline
