Tranny pan capacity
Hi there guys..... I am prepping for a trip from Central California to Great Falls Montana this weekend and I am going to drop the tranny pan and change the pick up screen as well as the in line filter. I have a few questions.
1. How much fluid does the pan hold? 2. I was told there is a service bulletin to switch to Mercon LV fluid but I can not seem to find it anywhere. Is this a Ford only product? I can find Mercon V all day long. The truck is a 2004 F250 PSD CC 4x4 with 90k on the clock. I am certain this tranny has never had a fluid change. |
I think you want mercon sp for it I'm sure one of the 6.0 guys can tell you...and I think it's says 17quarts in the owners manual we put 20 in my buddy's but that was completely dry new converter and everything..
Sent from my Autoguide iPad app |
Thanks for the info..... I will buy 20 to be on the safe side and if it comes up 17 I will just return the unused.
Mercon sp at oreilys
dropping the pan only takes 8 quarts
Mercon LV is also the new spec superseding the SP. They are backwards compatible though so get whichever is cheaper.
yup!
8-9 quarts by dropping the pan and changing the internal screen (only 8 quarts to drain it from the drain plug). |
Thanks guys for the info! Saved me from returning 10 quarts later! LOL
Sent from my DROID X2 |
OK so I replaced the tranny filter in the pan, the filter in line and drained the lines since I took the radiator out for a water pump swap and once all was said and done I put 11 quarts back in to get it just right.
