PMM coolant filter install question - Ford Powerstroke Diesel Forum
Old 06-19-2012, 01:13 PM
All,
Installed a PMM coolant filter in my 6.0 this past weekend. Very happy with the quality of the product so far; I chose it because it seems to be a good value and because it uses a "no cut" installation.
A question for those who have installed the same filter: Installing the tee in the heater line to supply the filter ends up pushing the factory heater hose back towards the turbo downpipe. I still have clearance between the two, but the hose sits only about 1 - 1.5 inches away from the downpipe. I'm concerned about the heat and the hose shifting and potentially melting if it contacts the downpipe.
I know I can just cut some length off the hose to move it forward, but since this is designed to be a "no cut" solution, has anyone done anything creative to keep the hose away from the downpipe?
Thanks in advance.
Old 06-19-2012, 01:23 PM
Alternatively, does anyone know the part number of the heater hose that the filter supply tees in to (the one that is cut with the other filter setups)? If it's cheap enough, maybe I'll just cut this one and order a spare in case it ever needs to be restored.
Thanks.
Old 06-19-2012, 01:24 PM
Feedback Score: 5 reviews
zipties to "pull" it toward the ac unit
Or just leave it be I don't see it being a problem!
Old 06-19-2012, 06:03 PM
I cut mine just seemed to close
Old 06-19-2012, 07:03 PM
I zip tied my to pull it away seamed to close to me and I didn't want to cut it
Old 06-20-2012, 05:26 PM
Thanks. I guess the zip tie that's holding the heater valve to the firewall is doing a pretty good job of holding it away. I may try to add some additional ties or cut the hose (moving it around too much seems to crimp the hose up from what I saw).
Old 06-20-2012, 05:29 PM
I didn't cut or zip tie mine. Still good to go after 10,000 miles plus...
Old 06-21-2012, 02:55 AM
I zip tied mine for a while, but I had to cut it when I did my oil cooler swap and never tied it back. I haven't had any problems either way.
Old 07-02-2012, 05:56 AM
Since the length of hose coming from the heater valve to the tee at the manifold is a relatively straight run, I've decided to order a 1 ft length of blue silicone hose that I can use to replace it, cut to the right length.
This way I'll be sure it stays away from the exhaust and I can put back the stock hose if I ever need to.
PMM should consider including this in their kit.
1 ft sections of the same blue silicone hose (3/4") with clamps are available on eBay for pretty cheap.
Old 07-02-2012, 06:01 AM
when
That type of filter only works when the heater is running ?
