Turbo problems? - Ford Powerstroke Diesel Forum
Old 06-18-2012, 12:43 PM
Turbo problems?
Today I noticed the turbo didn't seem right and seemed to smoke more then normal. I have pulled 3 dtc codes may e someone can help me what might be going on?
P0069
P0470
P0472
So what do they mean?
Thanks
Old 06-18-2012, 01:11 PM
huj huj is offline
Feedback Score: 3 reviews
p 0069 map baro correlation p0470 exaust press sensor p0472 exhaust press sensor low input
Old 06-18-2012, 01:14 PM
huj huj is offline
check hose from intake to map sensor
Old 06-18-2012, 01:15 PM
huj huj is offline
if you have scan tool acces data map baro and exhaust pressures with key on engine off should read the same or very close what year? is your truck
Old 06-18-2012, 01:19 PM
huj huj is offline
sorry ebp key on less than 18.5 psi and within 1.5 psi of the map and baro
Old 06-18-2012, 02:11 PM
I don't have any way to check these things guess I have to take it to a dealer?
Old 06-18-2012, 04:12 PM
Post in the forums for your area. Someone around you may have a AE scanner. Just ask Lots of great people on this Forum.
