Manual Fan Switch
Does anyone know how to add a manual fan switch to a 04 6.0l? I'm running a belt driven air compressor on my service truck and with it running the coolant temp seams to run about 220*.
Are you running using the high-idle? This is why the high-idle is in the factory programming, running accessories such as this. The directions to enable are in the tech folder.
Subscribed. I would like to know as well.
No. The air compressor's controller automatically adjusts the RPM as needed. I will be adding the high idle switch soon for warm ups.
Bismic sent me some info on the 6.0 . Its the best info I've gotten yet. I have a 06 psd and I was able to put a switch that would ground one of the wires to the fan clutch and it will engage the clutch in about a minute. When you turn off switch it takes about the same time to disengage clutch. Im not sure if its the same on your 04. There's 5 wires going to the fan clutch plug. On the engine side of the plug mine has a light blue wire that I ground threw the switch. It has worked well and haven't had any codes yet.
Sent from my DROID Pro using AutoGuide.Com Free App |
Link works
