Worse millage after egr delete
So before I did the egr delete and new cooler my delta was usually around 40-50* differnces and I was somtimes getting 22.5 mpgs on the edge Insight I don't know how accurate those are but anyway did the delete and new oil cooler and I'm getting around 16-18 depending on how I'm driving it. I'm not complaining with the millage just wondering why it would change so much with an egr delete? Also put new fuel filters in too at the same time and upgraded blue spring
Sent from my PC36100 using AutoGuide.Com Free App |
I explained it here. We were really talking about increased EGT's with the EGR delete, but the answer is the same reason for the lower fuel mileage. You can't really go by what your monitor say's your mileage is and I highly doubt you lost 4-5 mpg.
EGR Delete Question?? |
How do those mileage calc's work anyways? Do they look at fuel tank drop vs tire revolutions or look at fuel being commanded to the injectors for hours ran or something else? I always wondered.
To the op, with a 40-50* delta, you had one very well built egr cooler assuming it didn't bust and that was the reason for the delete. It will take a tad longer for the engine to warm up since the exhaust gas is gone and the 6.0 isn't very fuel friendly when cold. That may be some of what you are seeing as well. |
Yes I was scared to drive the thing with a delta that bad but it never rupture, I heard the 03 and 04 egr coolers are stronger than the newer ones. Now my delta stays right around 12*. is that common to lose mpg after an egr delete?
Actually at one point I had eot at 245 and ect at 185, 60*! Delta and I have a picture of my insight at those temps I think, and still never ruptured
And as my other post explained anybody deleting the egr system whill loose fuel mileage and see elevated EGT's. It's simple physics. kdogg I don't know how exactly they calculate fuel mileage but I've seen them be really close and wildly inaccurate. When I put the PHP FICM on my lie-o-meter went down by 5 mpg or so in spite of the fact I actually picked up a couple mpg.
