EGR Removal - Ford Powerstroke Diesel Forum
Old 10-05-2007, 02:01 PM
Ole White
EGR Removal
What does taking the EGR off of a 6.0L do for the truck my dad is thinking about taking his off of his truck
Old 10-05-2007, 06:47 PM
friendly bump
Old 10-05-2007, 08:14 PM
Removing the EGR prevents exhaust gases from entering the combustion process. Spool up is quicker as all the air flow goes to spinning the turbo. By adding exhaust air to combustion, the inert gases limit how much oxygen (fresh air) can enter the cylinder. Less oxygen = less powerful burn = lower temps.
Old 10-05-2007, 08:19 PM
The Fat Mod
There is a EGR delete kit out there somewhere I believe. Not sure where to find one, but it can and has been done.
Old 10-05-2007, 08:43 PM
say no to rolling coal
Are you talking about blocking the system, or totally removing it? It can be done either way, but the latter is a lot more work!
Old 10-05-2007, 09:52 PM
It also helps prevent an egr cooler failure.
Old 10-05-2007, 09:53 PM
The Fat Mod
I have my blocked off. But you can totally remove it too. I bet that would mess with a tech if they were not expecting to see it gone
Old 10-06-2007, 05:26 PM
I have a 2005 6 liter, stock except for AFE filter and Zoodad mod. Does it make sense to do the EGR delete to a stock truck, or will it raise the EGT's too much?
Old 10-06-2007, 05:30 PM
read threw this Complete Egr removal
Old 10-06-2007, 11:57 PM
It won't raise your EGT's, but you will throw codes and set off the check engine light without programming... Ask any dealer tech out there, its not warranty friendly to do to your truck, but it one of the best things you can do for your motor.
