preparing myself for head stud job.... - Ford Powerstroke Diesel Forum
Old 06-12-2012, 06:09 PM
so i'm trying to compare solution kits.. i already have an egr delete, just trying to get arp's, ford hg's, and cooler rebuild. best options so far:
1) Bulletproof diesel's kit
2) XDP's kit and just sell the egr delete
anyone know any better kits? I see xdp's kit has new exhaust gaskets but the bulletproof doesn't, will i need those? i hate how everywhere i look its a "complete kit" but they're all different
Old 06-12-2012, 06:22 PM
The Silent Service
Best advice I have for you, is ignore the marketing hype of a complete kit. Look at the individual components, and get the parts for your build.
A lot of that is covered here:
Write Up: Bullet-Proofing the 6.0L PSD.
I've covered part numbers, and options depending on what you want to do.
If you already have a delete kit, I'd get a full set of gaskets from Ford (Intake, EGR valve, Exhaust (depending on weather you are removing the manifolds), Oil Cooler, all the software). I would look at Ford's rebuild kit for the Oil Cooler which will just replace the internals of the cooler for about 1/2 the price. (You won't find that in any kit.)
Anything else you are looking to do while you have it torn down?
Old 06-13-2012, 12:42 AM
I didnt buy a kit either.. I got the headgasket kit from ford that came with most of the stuff needed. I got most of my parts from tousley ford and a few things from some other vender sites. The problem with the kits is they come with BO HG that nobody should use and my egr was deleted already.
Old 06-13-2012, 12:47 AM
Heres the list of things I ordered when doing my HG job.. I did the oil cooler re-build a few months before this so I didnt need a egr delete and oil cooler.
1) 5c3z-6079-g Head kit with 2 OEM headgaskets
2) 3c3z-9439-aa intake gaskets
1) 3c3z-9433-bj intake kit that dont come with gaskets
4)w300013 up pipe bolts
4)w300051 Y pipe nuts
1) ARP studs 250-4202
1) Pair of 6.0 heads ready to bolt on from Odessa Heads
Youll also need 2 dummy plugs that dont come with the head kit.
Old 06-13-2012, 03:26 AM
The cheapest place to get all the Ford parts is going to be Tousley Ford Parts Depot. I wouldn't buy a kit personally. Intake gaskets are reusable.
