New STC Livewire - Oil & Coolant temp seems high - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-12-2012, 01:00 PM Thread Starter
I just installed my new SCT livewire the other day and flashed the street tune to the truck. When I run around town and down the highway my temps vary below:
Oil: 200-220 deg F (212 average)
Coolant: 184-200 deg F (192 average)
Ambient temperature outside is around 90-95 deg F. I'm getting these numbers off the livewire display and they seem a bit high.
Coolant was flushed 6 months ago, EGR cooler is blocked off (no leaks). Oil cooler was done back when the egr cooler was done (approximately 2 years ago). About 6 months ago I put head studs in it as a result blown head gaskets at the time.
Any ideas? Or is this normal?
2004 F250 Regency
- 4" MBRP exhaust with cat delete
- Infinity mids & tweets, MTX 10" sub
- ARP head studs
- Black onyx head gaskets - these are s**t and have failed, replacing them with OEM HG
- SCT Livewire w/ Street tune
- IPR Gen 2 EGR Delete
- IPR Remote Oil Cooler - this is s**t, replaced with OEM and working great
- IPR High Flow Coolant Filter - this is s**t, replaced with PMM and working great
paintballrefjosh is offline
post #2 of 11 Old 06-13-2012, 01:41 PM
FalconLX's Avatar
hey josh, when you say the oil cooler was done, what was done? when you flushed coolant, did you run chem thru or what? the temps do seem a bit high. if during the coolant flush you ran chem thru, you may have "re-clogged" the oil cooler with the debris from the cleaning. did you run distilled water thru also? just a thought. how do you like the livewire?
2004 King Ranch SRW
CCLB
SCT SF3
Edge Insight CTS
MBRP 4" Turbo aft
AMSOIL synthetics
Bipass oil filter
Bipass coolant filter
Fog Light mod
High Idle mod
Kevins CCV
Dave
if you can read this, thank a teacher. if you can read this in english, THANK A SOLDIER.
FalconLX is offline
post #3 of 11 Old 06-13-2012, 01:47 PM Thread Starter
Dave,
Thanks for the reply. I replaced the oil cooler with a new one a couple years ago when I replaced & blocked off the EGR cooler. Also when I flushed the system I just used regular tap water, no chemicals or anything. I believe I used regular tap water too once I refilled the coolant, I can't remember exactly.
My thoughts on the Livewire are:
- it's quite big and bulky and the rj-45 connection is inconvenient for mounting
- the stats you can monitor are nice (that's why i'm posting here today )
- i wish there was an auto-off feature after it detected no activity (say after 5 minutes of engine off and no buttons pressed) right now I have to manually turn it on and off
- the refresh rate on the stats is so fast that the numbers blur together, especially on rapid changing values such as boost, sometimes i can't tell if i'm getting 18-19 psi or 8-10. this seems to be because the lcd screen is of poor quality, a more modern lcd would be better
- during a hot day or in direct sun it's very hard to read the screen until it cools off (due to cheap quality, same as previous)
Other than that it's not bad, I wanted it to monitor engine vitals and tuning
2004 F250 Regency
- ARP head studs
post #4 of 11 Old 06-13-2012, 02:02 PM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
I agree with the poor quality of the screen, what I do is when I know the truck is going to sit in the sun I pull the LW off of its mount and wrap it in a towel. Seems to do the trick.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #5 of 11 Old 06-13-2012, 02:17 PM Thread Starter
That's a good idea, I had been pulling it off and storing it in the console, but it can't breathe very good there.
2004 F250 Regency
- ARP head studs
post #6 of 11 Old 06-13-2012, 03:13 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
1. if your coolant temp is 200* at 65mph and your oil temp is 220* then the oil cooler is "done" (needs to be replaced).
2. You should never put tap water in your truck.....anywhere in the truck. You need to try and flush your coolant system with restore and then restore+ and that will hopefully clear your system but dont hold your breath. The tap water causes rust to build up in our trucks. After you do the flush, which needs to be done whether you replace the cooler again or not, whatever coolant you go with (I prefer an CAT rated ELC) you need to use distilled water not tap water.
3. Its not normal. Your EOT & ECT should be approx 190* The EOT ca n be from 190*-205* but should not be more than 205* or at most 15* more than the ECT at 55-65mph on flat road unloaded.
4. Yous should drop the Livewire and get a Insight CTS
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #7 of 11 Old 06-13-2012, 06:13 PM Thread Starter
WarChild,
Well it looks like I'll be putting a new cooler in it then. I've been looking around and the BPD external oil coolers sure seem like the smart thing to do, but they are quite expensive. Is there another alternative or is a stock cooler with the proper water/coolant good enough to last a long time?
I used the premium gold from Ford last time, should I switch to another brand if i'm going to flush the system?
Also what's the difference i EOT and ECT? Is EOT cooland and ECT oil?
2004 F250 Regency
- ARP head studs
post #8 of 11 Old 06-13-2012, 06:58 PM
F250SixOH's Avatar
ECT = Engine Coolant Temperature
EOT = Engine Oil Temperature
Also wanted to add that the ECT can fluctuate some above 190*. If you are towing, loaded, hills, etc. the ECT and EOT might increase. Under these circumstances the 15* thing is void. Just make sure that your oil temp never goes above 240ish and you coolant temp never above 220 or something like that. Your fan should be really loud and cool the coolant down if it gets to that point but the oil temp is very important because the oil will break down with enough temperature.
F250SixOH is offline
post #9 of 11 Old 06-13-2012, 07:03 PM Thread Starter
Got it thanks, I think I might do a chem flush and put a good coolant filter system on and see how it does. If I'm still having issues then I'll replace the oil cooler.
Thanks for the info guys, much appreciated.
2004 F250 Regency
- ARP head studs
post #10 of 11 Old 06-13-2012, 07:10 PM
F250SixOH's Avatar
Coolant filter is ALWAYS a good idea
