Variable turbo whistle - Ford Powerstroke Diesel Forum
post #1 of 67 Old 06-12-2012, 06:44 AM Thread Starter
I have a buddies who's turbo when driving at any speed his turbo whistle is going up and down very noticeably at constant speeds he has the same truck as me an 04 6.0. What could be causing this I thought it wasn't getting enough air so cleaned the filter and that didn't help does the turbo need to be cleaned?
2004 Ford F-250 6.0 CC SB
  • Edge Evolution
  • K&N FIPK Intake
  • MBRP 5 in Turbo-Back
  • 6.4 Banjo Bolts
  • Blue Spring Upgrade
  • Zoodad Mod
  • Sinister EGR Delete
  • BPD Oil Cooler (Condenser Mount)
  • SCT SF3 with tunes from Matt
dwpayne is offline
post #2 of 67 Old 06-12-2012, 01:14 PM
Razorsedge's Avatar
The turbo may need to be cleaned, or it could be the VGT actuator.
2005 F250 4x4 King Ranch 6.0
Two tone removed, Quad Captains, High idle mod
Edge Insight CS w/ EGT, fuel PSI, and turbo timer
4" turbo back straight pipe, Dieselsite coolant filter
BPD FICM, '03 turbo, IPR gen2 delete, Zerex ELC
Goodyear Duratracs, Tuned by Matt@Gearhead
Razorsedge is offline
post #3 of 67 Old 06-12-2012, 01:26 PM
Quoted: 364 Post(s)
Feedback Score: 5 reviews
Yours might be a later 04 and his might be and early 04 with the 2003 engine/turbo...
03 turbos have a reputation to have a LOUD whistle
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
post #4 of 67 Old 06-12-2012, 02:12 PM
Quoted: 48 Post(s)
he probably has an early 04 w/a 10 blade turbine
drunk on diesel is offline
post #5 of 67 Old 06-12-2012, 02:30 PM
Korx's Avatar
I have this same problem and was trying to figure out what it was. When I hold a steady throttle you can hear that the whistle isn't consistant right?
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #6 of 67 Old 06-12-2012, 02:31 PM
Razorsedge's Avatar
Leads me to believe he is asking about surging, not turbo whistle.
post #7 of 67 Old 06-12-2012, 05:08 PM
Korx's Avatar
I don't believe it is surging I looked at videos online of turbo surge and it didn't sound the same. Mine happens between 1500-2000 rmp. It's not a quick change in whistle for me its slow. It's hard to describe, ill try and get a video.
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #8 of 67 Old 06-12-2012, 05:32 PM
Send a message via Skype™ to bwmtnbiker
My turbo did this for a while but it happened after I did my oil cooler, egr delete and cleaned the turbo. When I got it all bolted back up and was going up and down like you describe. I decided to quit worrying about it as it was slowly getting better and now its just gone all together.
Mine I think was related to air or contaminants in the oil.
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #9 of 67 Old 06-12-2012, 07:50 PM
Korx's Avatar
Sorry for hijacking your thread. But I don't think it's an '03 turbo because I have mine straight piped and it doesn't quite whistle like '03 videos I've seen on youtube. Not sure what this could be. I may be due for an oil change, I have been waiting for EGR delete to do that. Might try to tackle cleaning the turbo when I do an oil cooler but I really hope this isn't a sign of a bad turbo
Korx is offline
post #10 of 67 Old 06-13-2012, 12:15 PM Thread Starter
No it's not an 03 turbo he has a late model 04 like I do and it is the same thing torx is saying that the turbo whistle is not staying consistent with the rpms. Say your cruising at 45 mph normally your turbo whistle will stay at one pitch his turbo sounds like when your reving the engine while cruising.
  • Edge Evolution
  • K&N FIPK Intake
  • 6.4 Banjo Bolts
  • Zoodad Mod
dwpayne is offline
