EGR Cooler Leaking what shoul i do - Ford Powerstroke Diesel Forum
Old 06-11-2012, 09:52 AM
so i had my truck in the local ford garage to be tested for lost coolant they told me my egr is leaking. so no brainer I'm going to do a delete but.... should i keep my egr valve in place? i run a sct live wire so can i just turn the valve off? i am going with the custom diesel econmomy delet kit but just curiouse what to do. the valve is only 8mo old thats in the truck now.
Old 06-11-2012, 10:08 AM
Yes, I believe the programming on the 04s won't throw a code if the EGR is deleted. My EGR is blocked off and I kept the valve in there. And even if it does throw a code some aftermarket tuning will take care of it.
Failed EGR coolers can be caused by a clogged oil cooler. Have you checked the oil temp compared with the coolant temp?
Old 06-11-2012, 10:10 AM
no i have not checked my temos my sct does not do eot just ect
Old 06-11-2012, 11:27 AM
Feedback Score: 3 reviews
Yes it will, you will need to download LiveLoad off the SCT website, and add the EOT PID to the Livewire.
How to get SCT x3 to read eot vs ect
Old 06-11-2012, 12:38 PM
Thats right, goto the SCT website to download. I had to call SCT customer support, because mine wouldn't automatically download. They can do a remote download for you, by sending you a link to your e-mail, and they can do everything for you. I got the EOT update, and it let me know that my oil cooler was stopped up. I Replaced it, and now my temps are normal. Just from my experience, if you're going to do an egr delete, go ahead and change the oil cooler, while you have the intake off. It will only take you about an extra 30 mins. It will save you time and money in the long run.
Old 06-11-2012, 03:45 PM
thanks guys i will have to pull my sct tommorrow and get that loaded
Old 06-12-2012, 05:37 AM
Ordered the oil cooler from tousley ford and ordering the egr cooler delete kit from custom diesel next and also a coolant filter kit from either XDP (Sinister kit) or PMM.
