CAT delete issue
Last week I deleted the CAT and replaced it with the MBRP 4" SS delete pipe. Yesterday when taking off from a stop light I had a poping sound from under the truck. My first thought was transmission because the truck jerked a little, but after hearing it a few times it seems to be the exhaust. Almost like a backfire. Any thoughts?
Thanks, Rick |
This happened under medium to heavy acceleration. Also, no smoke that I could see, and it didn't seem like an overboost.
I would see if anything is loose or bouncing against something
I made my Samsung SGH-I997 send this. |
I just took it for a test drive, I can't identify what the issue is. It doesn't do it everytime, but I can feel the stumble in the peddle. I can already be doing 50mph before it starts. I let off the peddle a little bit and it stops most of the time. It never lasts very long.
I check the exhaust, everything seems tight. Last edited by ralderman; 06-10-2012 at 04:50 AM. Reason: added info |
If it truly is a performance issue, maybe check your ebps and tube.
maybe it's leaking and had plenty of back pressure with the cat. Now it doesn't have a lot, which is good. But maybe the ebps is seeing little and is having issues? I made my Samsung SGH-I997 send this. |
It doesnt feel like a performance issue, the truck still pulls solid. My dad is sending my AutoEnginuity software back, I should have it in a few days. I'll check the sensor output. I may clean it after just to see if there is a difference.
I just checked my CCV reroute and has some slack in the supply line so I fixed that. It shouldn't make a difference, but just checking a few things on the truck. I also did a drain and refill on the transmission and changed the external filter. I did a flush and changed both filters about a year and half ago. From reading about the EBP, it could be the cause, and does make sense. Anyone know what the sensor should read normally? Thanks, Rick |
Check clearances around the pipe. It can be close to the crossmember or the body at times.
F250sixOh, great troubleshooting. I think that was part of my problem. The rear hanger was tapping the metal bracket next to the spare tire.
Now I have some type of intermittent grinding noise. I think it's in the front.
: ahem. I think I posted that first
