Coolant level low when engine was hot hot towing - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-09-2012, 09:45 PM Thread Starter
Quoted: 106 Post(s)
Feedback Score: 3 reviews
Just finished a long to trip from Cali to Oregon. Stoped to fuel up and I popped the hood to peak at my fluids. I notice the coolant looked really low. Checked for any leaks and I found none. Cracked the degas cap and the coolant started to flow back into the degas bottle. No pressure when I cracked the cap. Also checked my coolant filter hoses and both sides were warm. Later I checked when the engine was cold and the level was the same as before. So question is, do I just need to change my coolant filter or is something else wrong?
My deltas are good around 6-8 empty and the spread was no more than 16 for a moment going over the Ashland grade.
2006 F250 Carli 4.5" Pintop, Carli LT airbags, Top Gun Customz dual steering stabilizer, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS 2, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #2 of 5 Old 06-10-2012, 06:07 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
What do you mean low? What level was it at? It should be at or just below the bottom line on the Degas bottle. You had a long trip and if you were towing anything you could have list a.little but out.of the Degas bottle. When you take the cap off he Degas bottle there should be pressure behind it.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 5 Old 06-10-2012, 07:30 AM Thread Starter
Quoted: 106 Post(s)
Low as in I could barely see any in the degas bottle. But when I cracked the cap it started flowing back into the bottle. There was a little pressure, like a very slight hiss when the cap was released.
post #4 of 5 Old 06-10-2012, 08:55 AM
Galaxie's Avatar
Mine has always moved around like that. Expansion shrinkage
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #5 of 5 Old 06-10-2012, 08:57 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Yea sounds just like mine too. I would try replacing the cap though first to see if that is the pressure issue. They go bad often.
WarChild is offline
