Need help with part ID, number
It's the plastic wire tray that goes over and around the front of the turbo, with plastic push-pins to connect it to the body in front of the cowl. Holds the wire harness for HVAC. Thanks in advance.
![]() Surely someone knows what that part number is, or where to find it in Tousley's system! |
Might be this:
2005 FORD F-250 SUPER DUTY Parts - Tousley Ford Parts Depot Ask one of these guys if this is right: Can't find p/n..... And if it is, would you please post back, thanks. |
Thanks for the help! I will buy one and find out, then report back.
I do not insure that is correct number.
Tousley Ford can verify it. |
Some digging indicates that is the part number for the '02-ish trucks with the 7.3, which runs straight across and doesn't have the big arch towards the front. I think that's better, since you shouldn't need to break it every time you want to get to the turbo.
Since my truck is an '04 it may fit. It may put too much heat on the wiring due to being closer to the turbo, we'll see how it all looks when it arrives and maybe add a sheet metal shield. Once I have a replacement part, I'll pull the one off the truck and add the other part number to this thread. Thanks again!
Let's see if I can attach a photo... If so, this is part number F81Z-14A099-CA installed; it's the one for the 7.3s but seems to fit well enough after trimming the left-hand side at the degas bottle.
Original part is marked 3C3T-14A099-AE but this comes back empty on searching it Tousley's system. It does appear to be a valid part number elsewhere. |
