CCV O-rings - Ford Powerstroke Diesel Forum
Old 06-08-2012, 12:46 PM
CCV O-rings
Has anyone purchased the Orings that go on the elbow that enters the crank case vent box on the driver's side valve cover? I had a friend of mine to get me several parts a year or so ago as he was a mechanic at a Ford dealership and he said he couldn't find the crank case vent orings. He gave me what another mechanic said they use for that application but they were no where near the same size. I've checked assortment packs and haven't found the right size yet. I did a CCV mod later on after that and shortly after I noticed a pretty good oil leak and I can see a stream of oil coming from the elbow going into the valve cover where I used the old orings and had a loose fit at that location.
I haven't been to the parts dept. to see for myself whether they have them listed but if anyone knows for sure or the size and where I could find them I'd appreciate it.
Old 06-08-2012, 12:58 PM
Try this...
http://www.powerstroke.org/forum/sho....php?p=3030080
Sent from my SCH-I500
Old 06-08-2012, 01:07 PM
Maybe this one will work
6.0 Parts List By FORD?INTERNATIONAL
Old 06-08-2012, 01:19 PM
Originally Posted by southend View Post
Thanks for the link, valuable info there. I see a part # for what I think it is I'm looking.
Old 06-08-2012, 05:21 PM
I believe your looking for the pcv green oring.......
Old 06-09-2012, 08:07 AM
Go to fordparts.com type in either your vin or yr make and model, then search under part # 6766b You can view the diagram of the part there. This is ford's description "Engine Oil Filler Cap
6.0L OHV Diesel V8 ; O-Ring" But it is the right one
Old 06-09-2012, 11:29 AM
Tousley Ford Parts Depot
'green breather oring' is what you're looking for.
Old 06-09-2012, 02:01 PM
That's what I'm hunting.
Old 06-09-2012, 04:40 PM
^^^ it is listed as that.:thumbup:
