Uh oh, loud whining from turbo
874 views 4 replies 5 participants last post by  EvansF250
#1 ·
It sounds like a high pitch squeal, almost like toasted bearings. No smoke though. Any thoughts on what I should replace it with if it's the turbo?
#2 ·
It sounds like a cracked Y pipe. Are your sure its coming from the turbo? The Y pipe is right behind it.
#3 ·
Cracked y-pipe or cracked up pipe! Would be my guess first! Look in the flex sections! Bet that is what it is! Did you use the factory up pipe on ur egr delete?
#4 ·
Another vote for cracked y pipe
#5 ·
check your turbo boots, might were loose and causing same sound
