Pre-existing egr delete/headstuds? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-07-2012, 04:30 PM Thread Starter
I just bought a 2003 F350 srw with a 6.0 Powerstroke in it and I am aware of the common issues that these motors [I]can[I] bring along. I am fairly new to diesel trucks and I was wondering how I could identify if the truck already has an egr delete and/or headstuds... I understand that these items are burried under some layers but is there any way to tell if they are installed without digging through too many layers? The truck has 180k miles on it so I would have thought that if something was going to go wrong, it would have done so already.
Ronin114 is offline
post #2 of 5 Old 06-07-2012, 04:35 PM
The Silent Service
colo_dually's Avatar
Quoted: 32 Post(s)
Howdy and welcome to the ORG.
The EGR delete can be identified by looking under the intake manifold itself, in the engine valley.
Studs are a lot easier, look at the bolts holding the heads on. If it looks like a bolt, its the stock TTY bolt that stretches over time. If it looks like a stud (hex key imprinted on shaft) and a nut, then your truck is studded. This is not the cure all to keeping an eye on things, and depending on how the job was done the first time, it may need to be done again (when it fails, no reason to go back in there now)
Read the following thread on bullet-proofing and the core faults of the 6.0L:
Write Up: Bullet-Proofing the 6.0L PSD.
If you have questions let us know.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 5 Old 06-07-2012, 04:38 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Here are some pics.
Can you tell if your studs are done from the outside
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is online now
post #4 of 5 Old 06-07-2012, 04:46 PM Thread Starter
Thanks for the quick replies and the info, it appears that the truck has an egr delete but it does not have studs.
Ronin114 is offline
post #5 of 5 Old 06-07-2012, 04:51 PM
The Silent Service
Quoted: 32 Post(s)
With the delete in the truck, the coolant path that causes most of the HG failures doesn't exist. You should still monitor your ECT/EOT deltas for oil cooler replacements/rebuilds, but to prevent a rupture internal to the oil cooler vs a rupture of that EGR cooler which tears these motors apart.
Tags
egr delete headstuds
