Well after WAY too many problems with the 6.0, as well as being left stranded on the road at least4 times a year(thank God for AAA), I have finally decided to take the leap to the dark side.
I found a local place that is very knowledgeable who is going to do the cummins swap into my truck. I already bought the motor today(07 CR 5.9l cummins with only 66k miles) complete with everything. It is still in the donor truck and will be getting pulled out monday, then shipped to my shop. I will probably keep it stock for now until I can get everything to pass smog which I'm sure is going to be a headache.
I will keep you all posted of the progress as we go along. I am still trying to figure out which tranny I am going to go with so I can get all of the parts ordered. What do you guys think? I can either go with a built 47re, an Allison, or the 5r110/4r100. If I stay with the ford tranny, Brian from BTS and John from JWT both said I should go with a built 4r100 as they are a lot easier to program and can handle way more power than the 5r110. I have already looked into it price wise and found that the price across the board is not a whole lot different for any one I go with. I will need a stand alone controller with any of them which varies from 850 for the ford trannys, to 1500 for the Allison tranny, and 1800 for the 47re. The only thing with the 47re is that I won't need the flex plates and adapters so it evens the price a little. I talked to Auto World and they like to run the Allison trannys behind theirs. Problem is none of the shops including destroked have actually done a swap using the dodge tranny. What tranny would you guys go with?
And thoughts, suggestions or comments are welcomed.
EDIT 02/01/13: Well she is finally up and running after many months. Still have a few bugs to work out which are currently getting dealt with. I posted a video of it running which is on page 24, or you can click the link in my sig which will take you to the video. Pictures are kind of scattered throughout the thread. I will post a page with everything on it when it is completely done. Thanks
