Oil cooler delta - Ford Powerstroke Diesel Forum
Old 06-05-2012, 02:30 PM
Oil cooler delta
Finally got the insight hooked up. Cruising at 60 mph on flat ground unloaded I'm seeing 188 ect and 195 eot. Is that acceptable ?
Old 06-05-2012, 02:42 PM
Ford's max is currently 15*, used to be 20*....At 7* I'd say your fine provided the truck was fully warmed up and then still ran for a while to let it heat soak.
Old 06-05-2012, 02:59 PM
Almostdunfukinwidit
7 degrees is well within spec
Old 06-05-2012, 03:14 PM
Feedback Score: 5 reviews
Your good to go
I would still recommend installing a coolant filter to start cleaning the system...
I was in the same position as you before and before and decided to not install a filter....half a year later I was changing my oil cooler and Egr cooler
Just an FYI
