6.0 locking torq convertor - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-04-2012, 09:32 AM Thread Starter
jordan07's Avatar
what does it actually do? and why do u want it too do it ? im about too buy a tune for towing what gears should i have it lock up?
jordan07 is offline
post #2 of 14 Old 06-04-2012, 10:48 AM
Glow Plugs Only
dee004's Avatar
Subscribed
05 F250 CCSB 4X4, 05 VW TDI
4"Banks Turbo Back, ARP Studs & OEM Gaskets,
Coolant Filter, Blue spring, Zoodad
Bypass Oil Filter, Kitty By By, Standpipes dummy plugs
BPD oil cooler, EGR Delete, CCV Mod, BPD Oil Cooler, SCT SF3
dee004 is offline
post #3 of 14 Old 06-04-2012, 11:04 AM
Quoted: 364 Post(s)
Feedback Score: 5 reviews
I had a hard time trying to figure out what a toon was
Got it
Locking the torque converter transfers the power to the ground more effeciently then with it unlocked! But you don't need it lock up too early unless your at the drag strip... Just get a tune from whoever with their normal TC lock... (around 50mph IIRC) not the early one and see for yourself, then maybe have them tweak it to have the early TC lock in their and you will see the difference for yourself! Everyone is different!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 14 Old 06-04-2012, 02:59 PM
The torque conerter lock is exactly that, the TC locks and there is no slippage, a direct connection between the flexplate and front pump. Kinda like a clutch in a manual transmission. This is a great feature because you loose about 200 rpm with the lock up at lower speeds. More at higher engine speeds.
I have a tune that locks the converter early and I don't like it. Over 2000 rpm when the converter locks makes a turbo fart and a huge cloud of smoke if you are on a freeway on ramp trying to get up to speed. Ultimately I get pissed, hammer it, and the truck shifts 'normal'. Its either putt like a gram'ma or hammer down.
Normal TC lockup should occur at 45mph and light throttle pressure. More throttle, the later the lock. This actually feels like a 5th shift event.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 14 Old 06-04-2012, 04:15 PM
Glow Plugs Only
dee004's Avatar
I've read some of the tunes offered lock the converter in 1, 2 and 3 along with a Jake brake function if you want it. So would this be locked in 1 at about 45 mph and stay locked in 2 and 3 or would it be normal after shifting and lockup again at a pre determined RPM in 2 and 3?
dee004 is offline
post #6 of 14 Old 06-04-2012, 04:28 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Locking in 1st is a bad idea I believe. Not enough fluid flow or something to that effect.
The jake function is actually a turbo brake.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 14 Old 06-04-2012, 04:29 PM
I've only seen the real aggressive tunes lock in 2nd gear and it's for hauling a$$, not mpg. My tune that locks the converter does it at 42 mph indicated. (45 mph actual). Sounded good on paper, but it lugs the motor if you're not driving like a gram'ma.
Not sure what you mean by Jake brake function because the only Jake brake I know of cuts fuel to cylinders to help stopping power (big rigs). An exhaust brake will help maintain speed going down hill w/out needing as much brake pedal input.
Karls03 is offline
post #8 of 14 Old 06-04-2012, 04:30 PM
pizza pig's Avatar
pretty sure the tuning wont even command to lock the converter in first gear, no matter what, so its not even possible.
pizza pig is offline
post #9 of 14 Old 06-04-2012, 04:38 PM
Glow Plugs Only
dee004's Avatar
The jake brake function should really be called turbo brake as jsilvas mentioned. It commands the vanes of the VGT to increase exhaust back pressure to aid in braking using the exhaust back pressure.
dee004 is offline
post #10 of 14 Old 06-04-2012, 05:13 PM
Glow Plugs Only
dee004's Avatar
When does the converter lock in stock configuration? Is the converter locked when in overdrive?
dee004 is offline
