New ScanguageII - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-04-2012, 08:35 AM Thread Starter
cgunn's Avatar
New ScanguageII
Is there a place I can look up what to expect my
readings to be,or should be,on my new ScangaugeII??
I will be monitoring my 2007 6.0 PSD DRW with 124,000 miles.
I tow a 13,600# fifth wheel RV.
I have found several threads on this subject but
I still don't know exactly what is normal.
I am in Colorado where I will be pilling over a few
mountain passes.
I will watch ECT,EOT for sure.
What others are most important to monitor?
Thanks for your help...charlie
cgunn is offline
post #2 of 6 Old 06-04-2012, 08:37 AM
Quoted: 365 Post(s)
Feedback Score: 5 reviews
FICM Voltage
Battery Voltage
MPG is nice to track
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
post #3 of 6 Old 06-04-2012, 08:38 AM
Quoted: 365 Post(s)
Oh also, Tranny temp!
Studded and Deleted
post #4 of 6 Old 06-04-2012, 08:41 AM
ZMANN's Avatar
Quoted: 1596 Post(s)
He's looking for Values
We Miss you Ronnie
ZMANN is online now
post #5 of 6 Old 06-04-2012, 08:47 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
FICM Voltage should be no lower than 47 volts at any given time. And that's "FMP" on your Scangauge. Max would be 48.5 volts...
Oil and coolant temp should be between 190 and 210. There should be no temp difference (delta) between the two greater than 10 degrees.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 6 Old 06-04-2012, 09:03 AM
Quoted: 365 Post(s)
Tranny Temp= 140-180*
Battery Voltage= around 13v
FICM voltage= ^^^ is correct!
And I will elaborate on the deltas..
When driving 60-65 MPH, unloaded, on a flat highway, with the coolant temp atleast 190* you oil temps is 15* higher (I would start planning around 10*) then your coolant temp that means your oil cooler is clogged. If your oil cooler gets clogged it prevents the coolant from coming into your EGR cooler thus causing it to rupture, sending coolant into your cylinders. When that happens your Head Gaskets will fail.
All of the above issues can be prevented with keeping an eye on your deltas!
Also, If the coolant temp does not reach 190* that means your thermostat is stuck open and I stongly reccomend getting an OEM Motorcraft thermostat if needed
Studded and Deleted
