Loud screaching and rubbing - Ford Powerstroke Diesel Forum
Old 06-04-2012, 07:15 AM
Started the truck up this morning and turned on the on ramp to the highway and I had a loud screeching and rubbing/grinding noise that came from what sounded like front passenger wheel? But then just as I was going to pull over it stopped and went away once i hit about 60 mph. I am wondering what everyone thinks this might be. My truck is a 2005 F350 4x4. Any and all help would be appreciated.
Thanks
Blaine
Old 06-04-2012, 07:26 AM
Might want to check your hubs
Old 06-04-2012, 08:36 AM
A cat...............
Seriously, , a rock stuck in the caliper.
Sent from my SCH-I500
Old 06-04-2012, 09:45 AM
Well I will have to put it on the hoist tonight! I hope it could only be a rock. Thought it might have been a wheel bearing but if it was it should do it all the time right?
Old 06-04-2012, 10:52 AM
I have a noise coming from the front driver side. Thought it was a wheel hub. Wasted $250 on wheel hub. Cause that didn't fix it. All my u-joints feel tight. So I have no clue. Hope someone comes up with something for you. Maybe it will help solve my problem as well
Old 06-04-2012, 11:07 AM
Wheel bearing, yes, usually starts out as a rumble or grumble though. If it starts screeching your wheel should be falling off soon.
Old 06-04-2012, 11:44 AM
Mine starts at about 3 mph. And continues. Wheel bearing is all in one with the wheel hub. I replaced mine still no change.
Old 06-04-2012, 02:30 PM
You might have stuck caliper pins, some break pads have wear indicators designed to make noise, some pads just make noise for no good reason.
Old 06-04-2012, 03:03 PM
I replaced both sides with new calipers pad and rotors. 2 weekends before I replaced the wheel hub assembly. It's has to be a U Joint hopefully not the gears or transfer case.
