27 degree delta while towing - Ford Powerstroke Diesel Forum
Old 06-03-2012, 06:36 AM
On a two hour trip to the Florida keys recently towing a 5000lb trailer my freshly studded truck exhibited a 27 degree delta. I've also seen a 20 degree delta without a load.
The truck has a new oil cooler and an egr solution. It went through the mother of all coolant flushes prior to the mechanical work. I also run a coolant filter. I asked my mechanic, who is a specialist in the 6.0 what he thought of all this and he said it is no big deal.
I am not in the least worried. If I start barfing out of the degas I'll let y'all know.
Old 06-03-2012, 07:06 AM
what exactly is an "egr solution"?
Sent from my SCH-I500
Old 06-03-2012, 07:14 AM
5000lb trailer in FL should barely work the truck.
What are the actual temps?
Jason
Old 06-03-2012, 07:28 AM
War is the answer!
You need to test run for your delta while unloaded. On flat surface.
Old 06-03-2012, 02:36 PM
Thermostat??
Old 06-03-2012, 08:54 PM
Originally Posted by f350powerstroke View Post
Thermostat??
X2
Mine stuck half open before. Might want to put in a new t-stat if you haven't already. What were the EOT & EOC temps?
