thermostat time ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-02-2012, 08:19 PM Thread Starter
thermostat time ?
I went on a good 100mi. road trip today, deltas were very good EOT never over 197 even when pulling the altamont ( decent hill ) at 65 with about 2k in the bed, when the ECT was at 194 EOT 197 pulling the hill, but after the hill the ECT would drop to 178 and slowly come up to around 184 or so and stay in the 180's for a while the EOT would slowly come down and likes to run about 192-194 on the flat at 65, but the coolant likes to run low. So should I change the thermostat is it staying all the way open when it should close down some and keep the temp at 190 or above? Thanks for any and all input, Mike.
revised stc dummy and stands, blue spring, sinister coolant filter, riff raff boots, rotella 5w-40 t6, dead kitty, diamond eye 4in w/muffler, ccv mod, hole saw zoodad, edge insight cts, sct x3 innovative, on 07 drw f-350 4x4 lariat crew long. w/goose neck.
shadyford is offline
post #2 of 6 Old 06-02-2012, 09:01 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
When was the last time you changed it? It sounds bad to me and cant ever hurt to change it if it has been a while. They are cheap and easy to change.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 6 Old 06-03-2012, 02:59 AM
southend's Avatar
Just changed mine, it looked trashed when I got it out. I'm surprised it worked at all. It was running at 184 deg.
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 6 Old 06-03-2012, 03:07 AM
gdkrum's Avatar
I changed mine yesterday mine was running 183* to 194* and would take for ever to warm up. Now it runs around 190* all the time. So I think you might need a change IMO!
2007 F250 CCSB 4X4 King Ranch
Manual Transfer Case, K&N Cold Air Intake, SCT tuner, Fast Idle Mod, Dashboss, Clarion NX501 HU w/Sirius, Kobalt Tool Box, Goose-neck Hitch, Husky Mud Guards and Ventvisors.
gdkrum is offline
post #5 of 6 Old 06-03-2012, 04:23 AM
Yes you need to change it. Sounds like it's not completely failed open yet just taking a while to close back up after fully opening on the grades. Eventually it will just stick open and you'll never see 190* on your coolant! It's easy and cheap to do and your truck with thank you for it!
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #6 of 6 Old 06-03-2012, 09:46 AM Thread Starter
Thanks, I'll pick one up and get that temp where it needs to be.
