What is the part # for the Y pipe? - Ford Powerstroke Diesel Forum
Old 06-01-2012, 04:00 PM
I have found 2 different part #s for the Y pipe. I have a leak in the passenger side flex joint above where the EGR delete pipe is.
Which one do I need?
5C3Z-6K854-BA
5C3Z-6K854-CA
This one has the CA#
OEM LH SIDE TURBOCHARGER INLET PIPE FORD F250 F350 F450 F550 EXCURSION 6.0L V8 | eBay
This one has the BA#
NEW OEM LH TURBOCHARGER ADAPTER ASSEMBLY FORD LINCOLN MERCURY #5C3Z-6K854-BA | eBay
Thanks for the help!
Old 06-01-2012, 04:48 PM
5C3Z-6K854-CA is the part you need for your 07. the other number is for an earlier year model.
Old 06-02-2012, 06:43 AM
the early ones had the heat shield bolted to the pipe, the later ones have the shield bolted to the motor. My 06 had the shield on the motor. I strongly suggest not replacing with the stock part. Elite Diesel makes a better quality replacement for $$$ or I made my own for $50. See Really annoying whistle just started, help!
