Edge Insight CTS, Help please.. - Ford Powerstroke Diesel Forum
Old 06-01-2012, 11:07 AM
D_L D_L is offline
I want to keep my grab bar on the pillar so I don't want to put in a pillar gauge pod.
I have a SCT X3 tuner from Innovative Diesel.
What all do I need to monitor and what parts do I need?
I think:
Dash pod Mount kit. P/N 98003
Dash pod P/N 18302
EGT pyrometer P/N 98603 expandable
Transmission Temp. sender P/N 98608
EAS Universal Sensor Input P/N 98605
maybe, Fuel Pressure sender???
Edge Products| Product
http://www.edgeproducts.com/product_...cle-pdf-63.pdf
Thanks
Old 06-01-2012, 11:14 AM
The CTS will come with a suction cup mount. The dash mount and adapter thing kinda looked hokie to me... could be wrong.
If you purchase the EAS EGT Probe Kit it will give you the capability of adding things suck as fuel pressure. Its really trick... But you have to buy the sensor input kit along with the sensor kit. $$
I run the CTS everyday and LOVE it!!
Old 06-01-2012, 11:19 AM
I think:
Dash pod P/N 18302
If you want to keep your handle use the suction cup mount, I use it and it works great. good quality. You also don't need the trans temp sender, it will already monitor it.
Yes, get the EGT expandable, and the Universal sensor for a fuel pressure addon.
Old 06-01-2012, 11:22 AM
I was skeptical of the suction cup mount, but 6 months in the heat and havent had any problems.
You can monitor 8 things at once with that unit.
Fuel pressure, EGT, ECT (coolant), EOT (Oil), TFT (transmission fluid)
I also monitor ICP, FICM,and battery.
Old 06-01-2012, 11:24 AM
The Silent Service
You won't need the transmission temp sender, the CTS can read that via the OBII and on my truck its spot on with my aftermarket gauge.
I would just do the expandable hook up, with EGT and Fuel Pressure.
As for mounts, you have the standard suction cup that the CTS will come with or the dash pod. You will need the adapter plate for the dash pod, the CTS won't fit into it cleanly.
Don't forget to keep FICM voltage on your display as well as ECT/EOT.
Old 06-01-2012, 05:03 PM
D_L D_L is offline
Just got home, Duh couldn't remember what I had on my Dash instrument cluster when I started this thread at work.
I would just do the expandable hook up, with EGT and Fuel Pressure. Thanks everyone
Old 06-01-2012, 05:12 PM
Ditto! What he said!
Old 06-01-2012, 05:15 PM
Originally Posted by colo_dually View Post
Don't forget to keep FICM voltage on your display.
I remember reading this somewhere, but what does the FICM voltage have to be at regularly and what would happen to the injectors if it drops?
Old 06-01-2012, 05:29 PM
Feedback Score: 3 reviews
The Edge Insight should already read trans temp thru OBDII, so no need to buy the sensor for a add on.
