Seafoam in oil worked - Ford Powerstroke Diesel Forum
Old 05-31-2012, 08:13 PM
I put 1OZ per quart of seafoam in my neighbors truck. It runs allot better and he noticed that there is less engine noise. I will be putting it in my truck once I get to the end of my interval.
He also put it in his VW diesel and that use to smoke a bunch at start up. But not anymore
Old 05-31-2012, 10:03 PM
I ran a bottle in one oil change a couple of changes ago. Didn't notice any difference, but I wasn't having any issues anyway. Thought it would just do some cleaning.
There is a guy who runs it in every oil change, DSMMH, or something like that. Runs it in all his motors. Never an issue.
Old 05-31-2012, 10:10 PM
Originally Posted by amdriven2liv View Post
I ran a bottle in one oil change a couple of changes ago. Didn't notice any difference, but I wasn't having any issues anyway. Thought it would just do some cleaning.That is the same approach im going at with my truck.
Even though I have seen it with my own eyes that it works, for me I would not do every oil change. Now I could see myself using this stuff every 5 oil changes or so....
Old 06-01-2012, 10:17 AM
Thought I had heard somewhere not to use it in our engines but not sure why...
Old 06-04-2012, 03:02 PM
Do you plan on running it for the full 5,000 miles or add it a couple hundred miles before you change the oil?
Old 06-04-2012, 03:06 PM
Feedback Score: 5 reviews
HUEI engines is why.... Dont know exactly myself but IIRC it is because oil actually goes through the injectors to fire them... seafoam is bad in that area I believe...
Old 06-04-2012, 03:15 PM
I have been going 8,000miles on mobil 1 with the amsoil bypass filter. Right now im at 8,000 but will be going up to 10,000 and testing it. I will post the test when I get there.
When I use seafoam I use it at the end of the interval. I dont think it is able to withstand long durations of a full interval. So I plan on using it towards the last 500 or less miles of the intervals.
Old 06-04-2012, 03:17 PM
Cool thanks
Old 06-04-2012, 05:10 PM
Smokersteve, you run Mobil 1, there is no reason whatsoever to run Seafoam in your engine. If you think your engine needs cleaning look into Archoil ar9100 and leave the Seafoam alone.
Old 06-04-2012, 06:18 PM
I thought I read somewhere that the sea foam cannot withstand the pressures of the hpop and would cause problems over time. is that true?
