Another Blue Spring Mod Question - Ford Powerstroke Diesel Forum
Old 05-31-2012, 01:47 PM
I didnt use one part in the package from ford. It is a black step down spacer???? Did i need to install this? I didnt have one of these in the housing Before so I dont know where it goes. Thanks in advance. Dustin Ball
Old 05-31-2012, 01:52 PM
Feedback Score: 5 reviews
You don't REALLY need to use anything more then the actual spring.... So if you did that's great, but you don't need to worry about that peice
Old 05-31-2012, 02:44 PM
I did the blue spring update two weeks ago, I used everything, I had one oring left and realized where it went and got it right. All the old seals were hard and worn, glad I changed it all. The oring I almost missed was stuck on the hard black plastic piece, I had to oil the new one well and it was a tight fit. I have read alot of the post about how people don't use all the parts or cannot figure out where all the parts go, I just checked it over a second time. I hope those old parts continue to work for you.
Sent from my SCH-I500
Old 05-31-2012, 03:13 PM
I installed everything on mine and a fuel pressure gauge at the same time in the test port. Annoying because my presure fluctuates sporadically from 55-60 all the time.
Old 05-31-2012, 03:16 PM
I didn't use the little white plastic piece at the top, it wasn't there originally and wouldn't fit back on with my housing. Has been holding up fine for 10K miles...I didn't really understand the point of it.
Old 05-31-2012, 03:19 PM
Lol, I didn't understand the point of it either. It was under the old cap, I had a new cap and replaced it.
Old 05-31-2012, 03:24 PM
We are talking about the same thing right? That is if by "cap" you mean the regulator cover on the side of the filter housing.
Old 05-31-2012, 04:21 PM
Yep........just the way you said it
Old 05-31-2012, 04:34 PM
The little white piece at the top under the regulator housing cover is an air bleeder orifice (see figure 53 on page 28 of the 6.0L Coffee Table Book, 2003.25 edition).
Jonathan
Old 06-01-2012, 08:27 AM
I didnt use the black piece or the o ring for it. My old set up didnt have it so the new one doesnt either. my fuel pressure is 66 at idle and doest drop much under acceleration. I havent had a chance to go WOT due to the rain here.
