"High" km's on stock head gaskets?
My truck has 286,000kms and to my knowledge, the engine is stock. I am currently having no issues with puking, smoking, etc (knock on wood) but have been considering doing studs, oem gaskets, and a bullet proof EGR to put my mind at ease and to reduce needing new heads when/if the head gaskets blow.
Is there any way to tell if any of this work has been done already? I bought the truck used and there is no records of anything in the glove box or anything so I am assuming not. I will be doing the job my self in my shop with the cab on. Reason for asking is every thread I read, people are needing replacing within 100,000kms or even miles, just wondering if there is a good batch of 6.0's out there? Mines a 2005 Last edited by jaggermouth; 05-31-2012 at 09:21 AM. |
I did all that stuff when I bought mine used and it blew in a year. IMO until it breaks dont fix it
Yes there are good 6ohs out there
![]() I agree with not touching the HG until needed... What I will recommend though is a monitoring solution like an Edge CTS, Edge CS insights or a Scangauge2... You need to monitor your oil and coolant deltas, FICM Voltage, EGT Temp, and Fuel pressure at the minumum ![]() Also, an EGR Delete and a coolant filter would be great investments if you don't want want HG problems Let us know if you have any questions! |
Thanks fellas, I'm just such a pessimist. I got a good deal on the truck and wouldn't feel bad putting a few bucks into it. I just took a look at the lower part of the head and I can still see the head bolts, oh well, its been great so far! Just wanted an little bit of oomph but didnt want to risk the reliability.
You can still do that on stock HG and bolts
![]() Just get a monitor to make sure your oil cooler is healthy and get a straight pipe and an SCT tuner w/ cutom tunes for non-studded trucks... It's AMAZING
Um... aren't you the guy who is going to install new head gaskets and studs despite having no head gasket issues
Uh...NO!
My plan of action is the following... Change tune from Extreme Street to Extreme Race... Then get a bigger Turbo... Then get my FICM tuned by PHP... I know that one of those mods will lead me to see alot of white smoke... ![]() I will not install studs until needed, but I will persuade it to go sooner so I can stud it and install some 190cc injectors ![]() ![]() So technically you are wrong ![]() ![]() ![]() And BTW... who said my HG are good ![]() after all my boosted launches, 35PSI boosts, track runs... I just add coolant
hehe:I stand corrected. Your headgaskets will need to be replaced by the time you are ready to install the studs. If it ain't broke, you're not trying |
Thanks for the info ![]() I was just gonna keep those ones and install ARP's...I thought ARP Studs Solved Everything ![]()
Thats the way to need the work, add power. I'd hate to be driving my stock truck and need a huge repair. I'd rather have 400rwhp and then need the work
