Which one of these bullet-proof kit is a better chioce?
Hi, my 2004 F350 Super Duty needs a full replacement of EGR, head gasket, oil cooler etc. was looking online for some cheaper parts cuz the shop are way to expensive.
So I came upon this site called Performance Machine and saw 2 kits for the job and wondering which one would be the better choice? heres the link: Complete TOTAL Solution Kit for 6.0L Powerstroke Complete MASTER Solution for 6.0L Powerstroke Also if I look for a diesel mechanic to install these for me, how much would be a reasonable price/hour? Thanks all for helping me !
Careful with the Black Onyx head gaskets. I would use Ford Head gaskets.
Neither. Split it all up, get it all from different places. cheaper but not the kind of "cheaper" you're currently looking at. Tousely.com has good price on brand new oil cooler. brownsdiesel.com for studs. dozersdiesel or holderdownperformance for oem gaskets and orings. rivercitydiesel for egr delete. all jmo.
I would avoid both of these kits at all costs. Most of these kits are more for marketing and selling products that aren't necessary. The main issue I have with both of these kits is the use of Black Onyx gaskets, which have a higher failure rating than OEM.
Also, it is not always preferred to delete the EGR cooler depending on where you live and the strategy of your truck. Some of the latest flashes from Ford will throw a CEL upon deletion. An alternative to deletion is an upgraded unit from Bullet Proof Diesel. I'll append my bullet-proofing thread that discusses all of this in detail, along with what has worked for other members. As for labor costs, there is a lot that should go into the pulling of these heads. First, getting them tested, and ensure they are absolutely flat. If you have to purchase new heads, ensure those are taken and checked as well. Second, ensure that no corners are cut the job should take around 30 hrs (per Ford). Shop around for cheaper labor, by all means, but ensure the shop you are dealing with knows how to work on this engine and powertrain. There is plenty that can go wrong, from folks not knowing exactly what they are doing. The '05 trucks had a few year specific flaws you will want to correct while you have the engine torn down. These are explained in the thread as well, it will save you the cost of needing to go back into the truck later. Write Up: Bullet-Proofing the 6.0L PSD. |
![]() so far I found: River city EGR delete kit, holderdownperformance OEM HG and ARP stud<- cheaper than brownsdiesel, Quote:
-Installation of gauges or monitor like the Edge Insight CS/CTS. Since I do not drive the truck and I don't think my dad will even look at them even if installed I will just pass on these. -Replace the turbo oil lines, as required. I will look this up -Replace the STC fitting, stand pipes, and dummy plugs (2005-2007). Does a 2004 model need these modifications? -Updated Fuel Pressure Regulator Spring. Any sites that you would recommend me getting there from? Last edited by iCrazyNoob; 05-30-2012 at 04:22 PM. |
The '05 shouldn't need the new turbo oil lines. I would get the fuel pressure spring taken care of though. Six0~Storker covered the parts site. I would check with your local shop, just in case you can get a better deal. The majority of part numbers, and general prices, are covered in the my bullet-proof thread. |
Get a monitor... atleast spend $150 on a scangauge2!!!
Sent from my crazy phone that posts behind my back... |
