No start -- Help Please!! - Ford Powerstroke Diesel Forum
Old 05-29-2012, 03:55 PM
truck will not start.
batteries are charged, turns over, but wont start.
Almost sounds like last year when my crank position sensor failed.
Thoughts on what to check?
When I started the truck this morning (after sitting for 4 days) It took longer to crank. But it started a couple more times once warmed up without any issues.
The only thing that is weird, right before this happened, I took off a fuel line from my regulated return and replaced a fitting (it had been leaking diesel) SO I replace the fitting, and get the line hooked back up. Turn the key to pressurize the system a few times, Looking good at 60psi, but no start.
Cant think if anything I did when I took the regulated return off. Its mounted right near the alternator.
Old 05-30-2012, 03:48 AM
not pulling any codes on the scangauge.... Is there anything I can check with the scangauge (HP Oil?)
