2001 wheels on my 2006
I need to know if a set of wheels off a 2001 f250 will fit on my 2006 f250
If they are factory 01 wheels then no. Your truck needs at least 17" rims. If they are 17" or larger, they will fit, but the offset is different, so they will stick out a ways
What Adam said.
Yes with spacers..U.S. Alcoa 6061t6 billet aluminum, Lifetime warrentee, hub-centric and wheel-centric The spacers are roughly 3-5 times stronger than the Ford cast 20" wheels .
2" spacers will work without needing to cut off your existing wheel studs but will result it the wheel moving out more as this will change the back space to 3.75"..rather than 4.5" thats stock. We can get you 1.25" spacers but you will have to trim the studs shorter. But the back space with then be 4.5" and the rim will set like factory. PM if I can help. |
Yep..read wrong thought you wanted '05 up wheels on a '04 earyler...
Why would you have thought that he asked that!!! There has never been a thread asking that before ![]() Sorry, just had to say it. Greg |
thanks for the advise i just need some tires and found a set of 16's with a good set of 35's for 200 bucks but oh well i might just man up and buy the new tires for my 20's nut thanks again thats what i needed to know
