Where to buy stuff - Ford Powerstroke Diesel Forum
Old 05-28-2012, 04:08 PM
Where to buy stuff
It's about that time. Need to maintain my truck. Will need oil, fuel, tranny, and air filters (am I missing anything?). Also tranny fluid and oil (prob from WalMart).
In two weeks I try the oil cooler. It needs to be replaced, but I might try the Restore flush first. Then I need ECL coolant and a bypass coolant filter. If that doesn't work, I'll just order an oil cooler and EGR cooler from BulletProofDiesel. Distilled water I'll pick up at the grocery.
Where does everyone go? I don't mind going to the dealership, but when I replaced my blower motor, I paid 50% more than what I could have got it for online.
Old 05-28-2012, 04:47 PM
oil and fuel filters from performancetruckproducts.com
08 trans filter from tousely.com
I'd personally skip replacing the donaldson and get a drop in airaid or afe for the stock airbox. xtremediesel.com jmo
tranny fluid(mercon sp) from dieselfiltersonline.com
oil from napa.
Old 05-28-2012, 05:01 PM
I would get all of your filters and trans fluid from dieselfiltersonline.com. That way you only have to pay shipping to one place. The oil I would get at Walmart. Rotella T6 goes for $21.36 there if that's the oil you plan to run.
All of my work I had done at the dealer but it was for the most part under warranty. I'd recommend finding a reputable shop near you that knows the 6.0L well. If you can swing for the BPD oil cooler that's the best option. I didn't have the extra coin laying around for that kit when I had my truck worked on so I went with the semi-bullet proof kit from them.
Old 05-28-2012, 05:07 PM
you can do the oil, air, tranny fluids and filters all by yourself. xtremediesel.com and performanctruckproducts.com offer free shipping if you spend over a certain amount. I know with the fuel and oil filter combo from php it ships for free.
mobil 1 5w40 full syn for oil....from napa.
Old 05-28-2012, 05:46 PM
RiffRaffDiesel has some good prices as well
Old 05-28-2012, 06:39 PM
oem ford parts - tousleyfordparts.com much cheaper than dealer
oil - walmart (rotella t6)
coolant - napa or anywhere you can find cat elc coolant (i believe napa stocks zerex)
filters -i like dieselfiltersonline.com (motorcraft or racor)
