Stupid Question - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-28-2012, 04:25 PM Thread Starter
Lilfarmrboy's Avatar
Stupid Question
I try to avoid asking stupid questions but I really don't know the answer to this one so here goes... on a Super Duty dually, say your in a pinch without a spare tire or the spare is flat can you take off one of the duals on the rear and put it up front in an emergency? As in if you had one of the fronts go flat or had a blow out up front? Just so you are able to get to a tire shop to get your regular tire fixed. Someone told me you could but I think its fishy... but looking at the rims it looks like the rear is the same as the front just turned around backwards on the outside rear.
Thank you for my stupid question for today.
Now something more serious. What temps you guys running on the tranny for a 6.0? Mine has been running around 165 but now with the heat wave its been around 175 today running lite. So what is considered a high temp for the 5 speed torqshift? I also noticed that when my coolant got up to 210 the fan kicked on but that was with the tranny at 175 and the oil temp at 216, after a few minutes with the fan running then cutting out the temps were C:198, O:203, T: 165. Do these look right?
Lilfarmrboy is offline
post #2 of 17 Old 05-28-2012, 04:31 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
Feedback Score: 3 reviews
In a pinch any tire will do. Running a single wheel on the rear will get you to where you can get it fixed. I wouldn't haul heavy or tow heavy running a single out back on a DRW.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 17 Old 05-28-2012, 04:46 PM Thread Starter
So I take it you can use one of the rear wheels (rim and tire) up front from the rear then? Just wondering. I need to go to Lynchburg, VA tomorrow to see a family member that suddenly took a turn for the worse. I have had this truck now for about 6 months now but still haven't got a dang spare for it yet. Looking at getting new wheels next friday and keeping one of the old ones as the spare. I'm in a pinch so I really don't have much choice, but I will be traveling lite, no camper or load.
EDIT: I should add these are Ford factory 17 inch wheels just to clear up any confusion on my part.
post #4 of 17 Old 05-28-2012, 04:51 PM
N.S.D.Q.
Quoted: 108 Post(s)
While I have never owned a DRW I recall all the wheels are the same so they can be used in any position. You could use a wide (12"-14") SRW styled wheel in the back. Saw a guy that runs his DRW with 14" wides in the back. Took the front adapters off and ran regular wheels up front.
Maybe if you had access to some SRW wheels you could pull the front adapters...keep the takeoffs for the spares.
post #5 of 17 Old 05-28-2012, 05:02 PM Thread Starter
For the purpose of this trip I just need to know that I can just in case I have to. Hopefully I won't even have to think about it or do it lol. I like the setup I have now but I need some new wheels on her bad, the alloys on her now are dull as crap and we have tried everything to bring them back out. I think who ever owned her before me just ran some of those chome covers over the wheels.
post #6 of 17 Old 05-28-2012, 05:03 PM Thread Starter
Thanks for the input Heavy. Any info on the temps guys?
post #7 of 17 Old 05-28-2012, 05:59 PM
Quoted: 4 Post(s)
Im running the same roads. Ive yet to see anything over 196 ECT even running the a/c a lot. highest EOT was 206 pulling my 6500lb 7x14 trailer. Trans runs about 160 empty, about 165 loaded.
Highway temps are 188/190 ECT and 195-196 EOT trans stays under 160 while running a steady 60mph.
Jason
JasonY is offline
post #8 of 17 Old 05-28-2012, 06:17 PM
Turbos = Witchcraft
TooMuch03's Avatar
Hey I read on an RX-7 forum that oven cleaner works good to clean alloys so I tried it this past weekend on my rims and it did work well. Mine were all covered in brake dust and road salt. After te oven cleaner I just pollished them up with some rim polisher crap. I think it is a huge improvement. Maybe you could try that
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #9 of 17 Old 05-28-2012, 06:23 PM Thread Starter
So far I have tried everything from several big name polishes to even a light acid wash and then polish... nothing. I will try the oven cleaner though and get back with you on the results. May take me until Wednesday or so. As far as the temps, truck doesn't run hot, deltas are really great, just runs in the 200 range. I should say this was backroads and stop and go. Highway they seem to be the lower numbers I posted, which makes sense because of the increase in air coming into the engine bay and radiator. Maybe the radiator is pluged with some of International's casting sand???
post #10 of 17 Old 05-28-2012, 06:38 PM
Turbos = Witchcraft
TooMuch03's Avatar
Yeah I just sprayed it on the rims and let it bubble for 5-10 minutes than went to town with a fine wire brush.
2003 F250 6.0
Compounds FTW!!!
