Maybe forgot to tighten Fuel injectors when I did head gasket replace-help?
Ok guys, just spent three days with the cab off doing head studs and everything is a blur.I am doubting wether or not I torqued the injectors down in the passenger head. I ran the truck last night for 15 or so minutes to operating temps and other than a small fuel leak at the driver's side banjo bolt, everything sounded and looked good.
What would be tell tale signs that I forgot? Should I pull the valve covers to check? I'm physically and mentally exhausted ![]() Joel Sent from my Autoguide iPad app |
Thinking about it, I know that the oil log can't be tightened without the injectors being tightened down. Just hope that I torqued them too.
Joel |
Better to be safe than sorry. If the injectors are loose you will get combustion blow by which will burn out the o-ring and it will start dumping fuel into the cylinder.
Pop the valve cover off and take a look. Better to k ow for sure then hope it's right.
I'm just done with this truck after a four day fix. I will pull the cover and look though. Thanks guys.
