Edge cs or scan gauge II
I have the usual pillar boost, pyro and trans temp. I want more. Edge cs or scan gauge II. I think I'm going for the cs what's your opinions???
I like the Edge Insight CS, I think it looks better in the cab, and is more functional than the ScangaugeII.
Not sure about the Scangauge, but the Insight will monitor FICM voltage and can be expanded to cover Fuel Pressure. Both of which are important for protecting the Injectors from premature failure. |
Bang for the buck, I really like my ScanGaugeII. I spent less on that AND an Auto Meter Sport Comp fuel psi than I would have on a CS. This is NOT a plug and play like the Edge CS, codes have to be entered to tell the SCII what to monitor. But we're men, pushing buttons and fiddling with things is what we do! Another plus is that I found several codes NOT listed on the SCII page/instruction manual (yes I read that, too) right here on the Org.
If you want to spend less go SG. If you want good looks and all the options go Edge CTS with turbo timer and EGT probe. Also expandable for fuel pressure, oil pressure etc....
For a medium price that can monitor everything a CS/CTS can for $300, that price includes EGT and fuel pressure, take a look at DashBoss for iPhone/iTouch/iPad.
DashBoss monitoring review. |
Yeah I was looking at the cs.
