White smoke from exhaust - Ford Powerstroke Diesel Forum
Old 05-27-2012, 08:57 AM
Did a bit of research in this forum but can't quite find the issue I'm having so before looking at 1000 posts I figure I ask. I have an 07 F250 with 65K miles and it has been loosing coolant through the degas container for a while but never over heats and I simply replace coolant once in a while. Power seems fine but yesterday for the first time I saw white smoke coming out of the exhaust when I first started and it seem to go away after it warmed up some? I read in this forum in the past about head gaskets, EGR, turbo or injectors going bad. Any ideas on what to check for? A friend of mine had simliar issue and ended up spending $5K replacing gaskets and better bolts. Not looking forward to that if that's the case so I want to check other things before spending that kind of money.
Any help would be apreciated.
Thanks,
Ed
Old 05-27-2012, 11:45 AM
Feedback Score: 3 reviews
Have you read this.
Troubleshooting coolant loss (white residue around cooling system components(degas))
Old 05-27-2012, 05:44 PM
Is it pukeing or just loosing coolant? Sounds like a head gasket. I could be wrong though
