What are the normal ranges on CTS Insight - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-24-2012, 07:39 PM Thread Starter
legionxxii's Avatar
What are the normal temp ranges and numbers for everything the CTS can monitor. Im talking more past the EOT and ECT I know them. I mean like to tell that your turbo is good and HPOP and so on.
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
post #2 of 8 Old 05-24-2012, 08:29 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Well, it wont tell you if your turbo is good or bad. Look HERE
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 8 Old 05-25-2012, 03:01 PM Thread Starter
legionxxii's Avatar
That helped me with oil pressure but what about Barometric Pressure, ICP Pressure, Injector Pulse Width, Intake Air Temp, Mass Air Flow, TCC Duty Cycle, Variable Geometry Turbo Duty Cycle these are all things I cant seem to find any real info on
US ARMY 13F
post #4 of 8 Old 05-26-2012, 09:10 AM
EvansF250's Avatar
Bump, would like to know also
2005 Ford F250 Harley Davidson Edition
D.D.
EGR delete, ARP Headstuds, Edge Insight with Egt and FP, blue spring kit, 4in mbrp tb exhaust with 6 inch tip, 35 " Discover STT Tires, Sinister Coolant Filter, ELC Cat-1 coolant, Mobil 1 5w-40, PHP ATLAS 40, SCT Tuner w/ Gearhead Tunes, Warren 155cc/ stock, STC Fitting Update
EvansF250 is offline
post #5 of 8 Old 05-26-2012, 09:27 AM
The Silent Service
colo_dually's Avatar
Quoted: 13 Post(s)
I'll do my best to break these down for you:
Barometric Pressure - atmospheric pressure, and I've never watched this. Monitored more to know what's going on outside.
ICP Pressure - Injector Control Pressure - This effecively you HPO press. Should sit around 550-650 at idle depending on tuning. Cruising anywhere from 1300-1600, and maxed out at 4,000 at WOT if memory serves.
Injector Pulse Width - this is the actual time your injectors are being opened at any particular speed. Again this varies upon throttle responce and the tuning your running, and during engine braking periods the injectors remain shut and will display zero.
Intake Air Temp - Intake temp - should be close to ambient air temps unless your stuck sitting in traffic. Monitored more to know what's going on outside.
Mass Air Flow - How much air your turbo is moving through the intake. Not something I watch for so I don't have a range for operation.
TCC Duty Cycle - Transmission Converter Lock - not something I watch.
VGT Duty Cycle - Turbo Vanes - again not something I watch.
It's a starting point for you however, as I come across more Info I'll post it up.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #6 of 8 Old 05-26-2012, 06:57 PM
VGT% will range from 15%-85%. Under normal driving conditions it will be between 40%-60%. At idle it will be higher and WOT lower. I watch mine once in a while just to see how much movement I get. I don't know yet but I'm thinking that as the number moves less my turbo is starting to stick. I'm hoping to clean it sometime in the near future so I'll see after that if my numbers change.
Load% is another one I watch once in a while. Flat road at 35-40 mph I'm in the low 30's. When my rear caliper started sticking that number jumped to around 50% and a few times up to 60% on the same road.
Battery volts drop to around 11 cranking, close to 12 after starting and then 14 when the glow plugs are off. When the alternator went I saw close to 10 cranking and it never got above 12 after that.
There's another thread around her on this stuff... I wonder how long it will take me to find...
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #7 of 8 Old 05-26-2012, 07:13 PM
CTS Readings
That's the best one I found...
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
post #8 of 8 Old 05-27-2012, 08:25 AM Thread Starter
legionxxii's Avatar
Thanks guys thats the kind of info I was searching for
US ARMY 13F
