Turbo spooling and custom tunes
This truck is my first diesel that I have owned. Had a bunch of 7.3's on the farm I worked on when I was growing up but never wrenched on them. Always been a Ford man but decided to go the the 6.0 since I only got 8-9mpg with my old V10.
Here is my question. I have been reading about the time that it takes for the turbo to spool up. It that why the truck is slow from a stop, until the turbo has a a chance to spool up and build compression? Wrenched on my v10 all the time but never had anything with a turbo in it. I am currently stock (only owned it for a week so far) but u I have a SCT x3 but no tunes yet. Will custom tunes help the turbo spool quicker and help acelleration from a stop? On a side note if custom tunes are that much more impressive than stock I am going to be in some seroius trouble It already hard to keep my foot out of the skinny pedal. Better put as much in my ticket fund as i do into my mod fund.
Custom tunes help with the lag, try them first and if your still not happy, get your FICM tuned.
I'm sorry to tell you this but....... Custom tunes make a BIG difference in power than the stock tunes!! Start putting that mod money in the bank, most likely the first thing you'll need is new rear tires. LOL! |
I will actually be getting the FICM tuned in 2 weeks. I took my CTS when I went to buy the truck and saw that it was dipping to 41v right after starting. Got them to knock $500 off the price. Will be sending it off to Ed to get rebuilt when I go on vacation next week. I figured since I am sending it in it would be foolish not to have him throw a tune on it at the same time
Yes, a good custom SCT tune will make a BIG difference. To the tune of ( haha! ) about 120 horses and 248 feet of torque increase on a stock engine for an 2006 6.0.
So an fcim tune will decrease the turbo spool lag??
Sent from iPhone |
It stands to reason that it would. To me anyway. On the custom tune vs stock take off. Well um YEA it makes a HUGE difference. My 06 pulled 255 hp and 508 ft lbs of torque on the dyno at BDP I thought that was really low for a 6.0 anything. It took a while but I finally got around to getting my SCT and ordered my first tune from IDP, Eric knows his tuning, and I ordered the extreme street and you wanna talk about night and day it was unreal. I have not had it back on the dyno since, but from a standing start pedal to the floor turbo lag city with the stock tune to near instant spool and burning the 295's thru 3 rd gear and then a get in sit down shut up and hold on ride there after Yea there is a difference lol. I would not recomend doing that very often studs or no EGT's skyrocket and that is never good. I also have run IDP's extreme race which gives torque converter lock up in all gears and it bad azz as well. I currently run Johanathan at BDP's daily driver tune and it is hands down far and away better than stock and nearly doubled my mpg's which were nothing to brag about. I also have his race tune and it is great as well. Since the truck is going to be out of service while you are on vacation I highly recomend that you do your coolant flush before you pull it apart. I recomend you either use the flush from ford or get you some restore which will remove the silicate sludge that may be present and then use a extended life coolant that does not contain silicates I believe it is referred to CAT EC- 1 rated coolant. It will save your egr cooler which will save your oil cooler, or even better do this and delete the egr system all together. |
the ficm tune helped mine spool a little faster mike |
