UpPipe question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-24-2012, 12:39 PM Thread Starter
UpPipe question
Are there any advantages to just welding up the uppide vs. deleting the EGR cooler?
2007 Lariat Crew Fx4, 20x9 D.E.J Wheels, 37x13.50, Toyo MTs, 6" Lift, Billet grill, '08 Mirrors, 4" TB Diamond Eye, AFE CAI, PMM coolant filter, Blue spring mod, Scangauge II, Pod mount FP gauge, SCT X3 - Looney tune
1fast68 is offline
post #2 of 10 Old 05-24-2012, 01:42 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
The only advantage is in being able to fool a visible inspection. It still leaves the scoop in the up-pipe which hurts turbo spool up.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 10 Old 05-24-2012, 01:49 PM Thread Starter
Can the scope be cut out when the pipe is welded up?
1fast68 is offline
post #4 of 10 Old 05-24-2012, 01:50 PM
You can cut the scoop out pretty easy or if you have an 04 like me there isn't even one to cut out... If you live in Cali or are broke then welding it up is the way to go... If you are anywhere else and have $200 just delete it and gain some peace of mind
BeXtreme04 is offline
post #5 of 10 Old 05-24-2012, 02:12 PM Thread Starter
The cooler was replaced about 7k miles ago so I know it's in good shape but I would like to just prevent the exhaust flow for now. Mine is an 07.
1fast68 is offline
post #6 of 10 Old 05-24-2012, 03:17 PM
PGreenSVT's Avatar
It would be tough. Easier to buy an 03 up-pipe that doesn't have a scoop to begin with.
RIP Mitch
the Org crew
post #7 of 10 Old 05-24-2012, 08:26 PM Thread Starter
Thanks guys.
1fast68 is offline
post #8 of 10 Old 05-25-2012, 04:30 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 104 Post(s)
Cutting out the scoop is easy...just need to know how to use the equipment.
Welded up-pipe or delete kit both work well. #992 on how to skin that cat!!
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 10 Old 05-25-2012, 05:23 AM
Aren't they different dimensions than the later model year up-pipes ....
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #10 of 10 Old 05-25-2012, 07:29 AM
Quoted: 28 Post(s)
The difference the 03 and early 04 have a different egr cooler flange(round type of egr cooler). The late 04 model has the square type of cooler and has no scoop for exhaust flow. 05-07 have the scoop and are made for the square type egr cooler. I just bought a late 04 model egr pipe and am putting it in with my new modded uppipes
Square type of egr cooler has a SHORTER pipe/neck to connect to the uppipe
Round type of egr cooler have a LONGER pipe/neck to connect to the uppipe.
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
