Pulled the heads and nicked a wire an injector
Just as the tittle says i dont know how but i ever so slightly nicked the sheathing on one of my injector wires is this something that can be repaired or do i need to replace the whole injector and if i do need to replace any ideas on where i can get a new one asap like by the this coming weekend
Sent from my DROID2 GLOBAL using AutoGuide.Com Free App |
Any ideas
Heat shrink?
Sent from my Acer Android Tablet |
Can't get a heat shrink over it. Clean the wire with alcohol, and spray it with a few light coats of Duplicolor Plasticote.
How many wires did ya get???? If its only one, I would suggest getting some thin splicing tape or and just wrapping the harness with electrical tape (stretching it while wrapping). Not argueing with anyone, but electrical current flows/travels on the outside surfaces of the conductor- not through the conductor. Plasticote "can" seep down in between the strands and cause a resisatnce issue with the circuit. Regardless of what you do, it will never be back to factory, so you will have to live with that fact! At least if you ever have an issue with that particular injector, you will know the first place to check!
Oh yeah, wire is not completely broke....
use a wire pin tool to remove from inj. plug socket
then heat shrink will go over no problem then put pin back in socket |
Whs::: do it right the first time.
Thanks for the ideas but i have been thinking about it and im just going to replace the injector i dont want to get it all back together only to have an issue later just seems like im only buying time with a fix
