What pads and rotors do you guys run?!?! - Ford Powerstroke Diesel Forum
Old 05-21-2012, 06:28 AM
Hey guys I'm getting ready to do brakes all around just trying to get a ideal of what pads and rotors you guys are running. I want to run slotted rotors but any suggestion are welcome, and as for pads I was thinkin about ebc green stuff.
Sent from my PG86100 using AutoGuide.Com Free App
Old 05-21-2012, 06:41 AM
I'm running ebay specials. Call me cheap! Slotted and drilled rotors and pads for $145 delivered. It seems to stop at least as good as stock, but the pads are wearing a bit quicker (I drive hard). At that price I'll put in pads when I need to and then next time, new pads and rotors again. The most critical (and most overlooked) thing is servicing the calipers. They need to move freely on their guide pins. The fluid should be changed yearly, and if the pads are wearing unevenly or quickly, for no other apparent reason, they should be rebuilt. Corrosion and debris will accumulate in the caliper, and even if the seals are not leaking, they loose seal tension and this can cause the caliper to drag.
Old 05-21-2012, 07:05 AM
OE rotors with Centric Posi-quiet pads.
Old 05-21-2012, 07:11 AM
Powerslot cryoed rotors and hawk lts pads. Impressive how good it stops over stock, imo.
Sent from my droidx using autoguide app
Old 05-21-2012, 07:18 AM
Chapter Director
Stock rotors and hawk pads and I dont have any problems stopping on 38x15.50 tire even when towing.
Old 05-21-2012, 09:39 AM
Suck, Squish, Bang, Blow!
Stock rotors and pads. But I might switch to an aftermarket pad if I can't get them to stop squealing.
Old 05-21-2012, 09:48 AM
Hey guts thanks for the quick replies, I also want a pad that won't have as much brake dust
Old 05-21-2012, 09:53 AM
EBC Greenstuff for pads then.
Old 05-21-2012, 10:12 AM
Diesel Mechanic Poser
+1. Cryo rotors and Hawk
Old 05-21-2012, 12:51 PM
Stock rotors and Hawk Super Duty pads. Love them.
