got to know - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-20-2012, 10:56 PM Thread Starter
got to know
Just got my first diesel Today. Lot to learn just would like some stright answers to..
Bad problems, 6.0 is the worse, chip no chip, ????? A lot of different answers!!! Did I get a deal?? 06 F250 Lariat extended cab 4x4 fully loaded 95000 miles one owner..Beautiful Truck!!! 16,900.... Only had it for 30 min, and a warning
light came on with a beep, saying I have water in the fuel.. Had a friend to help me out.. we found the filter but we could not find how to drain the water HELP!!
06pat6.0 is offline
post #2 of 5 Old 05-20-2012, 11:22 PM
There will ethier be a yellow lever near the fuel pump or an allen key drain plug right on the side of the fuel pump.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #3 of 5 Old 05-21-2012, 12:44 AM
Mike Hickman's Avatar
My 06 did this and was a bad wif sensor had dealer replace it no other problems ... The drain plug is on the frame rail right under the driver side door , Allen head . Best thing to do get the wif sensor check for corrosion which was my problem. It's a few dollars but get the fuel filters changed. Who's to say when the first owner had them changed injectors are not cheap , 400 plus for them . Good luck.
TRUCK WAS STOLEN NOW IS SOLD 2006 Lariat FX4 F-350
7" BDS Lift
SCT Xcal3 Tuned By Truck Source Diesel TSD with SPD !
Triple pod Auto Meters
4" MBRP Exhaust
Straight piped Turbo back
Zoodad Mod
325/65/18 13.50's MTZ
18x10 Mickey Thompson Bead Locks
A1 H11 Studs Head Bolts/Studded
EGR Deleted
Harley HeadLights
S&B Intake
Mike Hickman is offline
post #4 of 5 Old 05-21-2012, 01:17 AM
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #5 of 5 Old 05-21-2012, 01:31 AM
Get the updated plug for draining the water - it is all brass and will not get stuck from corrosion.
Knob style HFCM drain plug 6E7Z-9C082-A
If the WIF light is on constantly, you may beed to try blowing a cleaner (powderblast, carb cleaner, etc) into the drain hole. You will need to pre-bend the plasttic straw to a right angle to get it oriented where it will do the most good. If that doesn't work, then you will need a new HFCM manifold cover, which is not that expensive.
You can shop around and get Ford remanned injectors for close to $300 if it comes down to that.
If you need parts, use TousleyFordParts. Great on-line system and they will be very helpful over the phone of you need to talk to them. We can get you part mumbers for most things, so post up what you need if you want that kind of help.
As long as it is taken care of, you got a very good deal.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
